I’m drinking the rogue coolaid! And it’s really good!
mikeyb128
I hate to throw numbers out there. But I’ve only spent about 4 years in the 2 channel
Realm. At first I only cared about what sounded good, I was enthusiastic and everything sounded really good!
Unfortunately after some experience I started to get serious, I found myself listening far too critically of my system, I started noticing my enjoyment was being destroyed by my obsession. I was obsessing over the most minute detail. And even worse, I was getting hung up on brand names. I had some really nice gear go through my house, and I just wasn’t enjoying it.
Luckily I spend a fair amount of time in a friends hi-end Audio shop. Listening to expensive systems. And these guys do a lot
Of comparisons, and what’s even better is they’re honest. I’ve ditched some much more expensive brands, and what I’ve found is a real VALUE is Rogue Audio. I have had a stereo 100 in my house for about 3 weeks and this 100 Watts has been the most enjoyable music I have had in a looong time,
And this thing Is super powerful and graceful. For my ears it kills my bryston 4B3 in almost every category except for raw ear bleeding output.
What an amazing amp for the money! Please don’t over look these guys. I swapped the 12AU7S out for 50’s Westinghouse long carbon black plates (thanks Brock) and 50’s Raytheon 12AX7 Long Black shiny plates. The combination is stunning.
2 channel:
Theater:
Theater:
I’ve tried many tube combinations on my demo (broken in amp) including 57 herleen Holland long plates, long plate Mullard (Mitchum r code), Valvo Hamburg long plates. And the tube combination of Westinghouse and Raytheon has been the most natural, balanced and stunning soundstage.
As an example herleen long
Plates had an almost unrealistic holographic soundstage that ruined the music. The soundstage wrapped around your head, it was fun and amazing, detailed, but ultimately fatiguing.
I prefer things to sound pleasing, realistic and easy on my ears.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
The soundstage is wide, deep, extended on every frequency without overdoing it. Bass is tight. Sometimes I forget it’s there, then it comes on with unexpected authority. It’s detailed without fatigue. Simply amazing! Cymbals have this shimmer and decay that last forever. Did I mention this amp is solid state quiet? This thing also has a switch that puts it into single ended triode ( I think) and the 60 Watts is simply stunning. A little less grunt. But holy **** it’s sound clean.
I was always told my focal Electra’s were hard to drive. Dipping into 3 ohms but at a 91.5db efficiency, in my room these bad boys are killing it.2 channel:
Theater:
Here's some pics of this cool looking product:
Here’s more/actual shots, individual tube bias was all over the place until after about 30 hours, then things locked into place nicely. I’m not a fan of new production tubes, but I have to say these Tung-Sol kt-120’s are a work of art. Absolutely gorgeous tubes, the build is top notch.
2 channel:
Theater:
I have a set of M-120 mono blocks and Magnum 66 pre.......
Beastly combo.
Good info.
Hmmm, which way to go. -
nice system you put together man, sweeeeet !HT SYSTEM-
lsi 9's -
I loved my Rogue Tempest Magnum integrated but my Octave V 70 SE bests it in every
way.If you can't hear a difference, don't waste your money. -
I had and still have the issue of having to back off of my obsession over the little things. Yeah my system is far from perfect, my roo mb is far from perfect and my source is far from perfect but if I am in the right mood it just sounds fantastic.
Need to remind myself to get off the judges seat and just have fun.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
I always liked Doro (Mark). Get off the path. Sometimes you find something worthwhile for you.
Congrats! Nice gear! Love that Space 294! Definitely off the path. Lots of folks overlooked Nottingham.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Beastly combo.
Now if you could just get them out of long term storage and actually listen to them...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Awesome!
Those early "true" Westinghouse made tubes are simply fantastic. One of the true hidden gems as they tend to be kind of rare to find the real deal.
The Raytheon 12AX7's are no slouches either. If you haven't, try a pair of '50-51 black plate Tung Sol 12AX7. One of my favorite combo's is the Tung Sol 12AX7 black plates w/the Westinghouse 12AU7 black plates. Be careful, both are very hard to find and most out there are relabled common tubes like RCA or Sylvania.
You really have to pay attention to construction cues to make sure you are getting what's advertised. Both the Westinghouse and Tung Sol bp's have very specific construction identifiers.
My first Tube Preamp was a Rogue Audio 66 Magnum, at least 10-15 years ago. Have had a piece of their gear in my setup ever since. Good Value, GREAT Service.
btw, Spectacular Two Channel rig you got going there!
First weekend in a long time where I didn’t have anything to do! Was able to really sit down and have a few late and long listening sessions. The break in has been a bit of a roller coaster, but the rogue is breaking in nicely, and is sounding buttery smooth. Nothing budget sounding about this amp. At a cost of almost half of the Bryston 4B3 this amp is killer. I’m still shocked that 100 Watts is driving my Focals to the moon! No signs of compression, and the dynamic range is excellent!
Thanks for all the comments everyone. I have a audioquest thunder power cable on the way for the amp, will swap out my excellent sounding ZU Audio Event, and see what happens.
The bass on this amp is killer! Bone crushing bass from this beast. Absolutely loving it. Stayed up until 3AM twice this long weekend. Been a while since I’ve enjoyed my system this much.2 channel:
Theater:
Awesome!
As always, you make excellent recommendations. I’m thinking of some 5751’s in the AX7 spot. The problem is that I don’t have any! I have hundreds of tubes. But not one pair of 5751’s! Just what I need is to buy more tubes! Lol2 channel:
Theater:
You can never have enough...
Glad you are enjoying the Rogue. I have a Cronus Magnum ll that I really like. I agree, there is nothing"budget" about their products. I have some 5751's in my tube stash. If you are interested in a pair, send me a pm and I can see what I have.
Awesome!
Did you get a pair of Tung Sol 5751's from me or what that Kerry? If not, I highly recommend the Tung Sol 5751. The earlier ones from the late 50's with the horseshoe getter is a tad bit better than the early 60's version. But they are both superb.
GE black plate, early 3 mica with sq getter is excellent as is either the early gray or black plate Sylvania's. But you pay a mint for those especially the Sylvania's. Tung Sol's sort of fly under the radar and I actually prefer them to the Sylvania's.
I'm using a pair of mid 50's Raytheon, 3m, bp, sq getter right now, another superb choice....hard to find. The later 3m bp windmill getter seems to be more available but will set you back some $$$. I think the highs and mids are a bit sweeter with the non-windmill version, but again, both are excellent.
I ordered some Raytheon from the Russian guy.
I hope the screen print is dry.....
LOL
Kidding Kerry -
What screen printing? He assured me they were Raytheons, even scribbled it on the box! What more do you need?
At least it wasn't done with a Sharpie! Has to be legit.
