New 2.3tl boards are done
pitdogg2
Now to install next week once quick connects from Mouser arrive to be able to hook up the new 16mH inductors.
Thanks to Dave at DHS speakers for the help on the inductors he provided.
Some serious component po rn there Ivan...My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Very nice. Wish the inside of all speakers came like this from the factory!
Yea I know Paul, but it makes it so easy to switch between new and old XO to compare. I still plan on putting new wire, binding posts and nutrik connectors for the Dreadnaught when money catches up until then this is what it is. If it's any consolation I did use silver wire for my jumpers, got me some hot rod wire jumpers pal
Thanks, Tony created some great boards. -
Nice Job Dogg! Drooling here!
Still got my 1C's XO's on Larry's boards that David @westmassguy did in the corner. Winter project!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Those look like they are yearning to be installed and broken in, get on it Ivan then report back.Home Theater
Dem's purdy. Nice work.
Nice work!Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Thanks guys.
Steve they will go in next week and I'm definitely looking forward to be able to sit in the sweet spot. -
So last night I got to finally install my new boards and inductors. Boy was I surprised at what I found. Large value caps basically bypassed with smaller value caps to make the value needed 12uf with a 4.2uf for example. There was also a correct cap 18uf bypassed with another 5.8 cap. Now I know why I could never get them dialed in. My room is not in the least the best for these speakers but my living arrangements are for the moment just a temporary stop, so one day I will have a better room for them. Still the XO must of been made on a day when someone re-upped their grass supply.
very nice.
I've seen worse than those Ivan. Capacitor values all over the place, and inductors too.Home Theater/2 Channel:
dhsspeakerservice.com/ -
I believe you there Dave. I did wonder how close my inductors were to spec when i seen this.
