New 2.3tl boards are done
pitdogg2
pitdogg2 Posts: 27,234
edited September 2018 in DIY, Mods & Tweaks
Now to install next week once quick connects from Mouser arrive to be able to hook up the new 16mH inductors.
Thanks to Dave at DHS speakers for the help on the inductors he provided.
Post edited by pitdogg2 on
  • Some serious component po rn there Ivan...
    Garage | Polk Monitor 5B's
    Clipdat Posts: 13,100
    Very nice. Wish the inside of all speakers came like this from the factory!
    Yea I know Paul, but it makes it so easy to switch between new and old XO to compare. I still plan on putting new wire, binding posts and nutrik connectors for the Dreadnaught when money catches up until then this is what it is. If it's any consolation I did use silver wire for my jumpers, got me some hot rod wire jumpers pal :p:p
    Clipdat wrote: »
    Thanks, Tony created some great boards.
  • verb
    verb Posts: 10,176
    Nice Job Dogg! Drooling here! :smile: Still got my 1C's XO's on Larry's boards that David @westmassguy did in the corner. Winter project! :smile:
    gudnoyez Posts: 8,174
    Those look like they are yearning to be installed and broken in, get on it Ivan then report back.
  • FTGV
    FTGV Posts: 3,650
    Dem's purdy. Nice work.
    SCompRacer Posts: 9,121
    Nice work!
    Thanks guys.
    Steve they will go in next week and I'm definitely looking forward to be able to sit in the sweet spot.
    edited October 2018
    So last night I got to finally install my new boards and inductors. Boy was I surprised at what I found. Large value caps basically bypassed with smaller value caps to make the value needed 12uf with a 4.2uf for example. There was also a correct cap 18uf bypassed with another 5.8 cap. Now I know why I could never get them dialed in. My room is not in the least the best for these speakers but my living arrangements are for the moment just a temporary stop, so one day I will have a better room for them. Still the XO must of been made on a day when someone re-upped their grass supply.
    edited October 2018
  • westmassguy
    westmassguy Posts: 6,850
    I've seen worse than those Ivan. Capacitor values all over the place, and inductors too.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    I believe you there Dave. I did wonder how close my inductors were to spec when i seen this.
