Schematics for DSWmicro PRO 3000 plate amp
Hi all,
I’m looking for schematics for DSWmicro PRO 3000 plate amp.
I have two units. One uses audio signal auto sense on the LFE port and it’s working fine for automatically turning the sub on and off. The other is close enough to my receiver it uses the 12v trigger. Recently, I noticed the 12v trigger unit no longer works to turn the sub off. I tried with either audio signal auto sense or the 12v trigger. When I manually power cycle the sub the auto sense and the 12v trigger works to turn the unit on and for some time it works then hangs in the on position. Once it hangs in the on state, removing the 12v trigger or the audio signal has no effect nor does the 3 position switch for auto sense, off or 12v trigger, only using the mains power switch turns the unit off.
  • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
  • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
  • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
  • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
  • Office-2.1 B&W Formation Duo and Bass
  • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
  • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
  • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
  • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
  • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
  • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • @KennethSwauger
    I’d love a copy of the 2000 for myself as well lol
  • mpitogo
    mpitogo Posts: 516
    I have a workaround which is to use a switched port on a surge protector. The switched port is triggered on/off with my amplifier. This works great except for the large thud everytime we turn the system off and it’s at least a few times a day as it’s in our main family room system.
  • Hello,
    I recommend sending an email to: Ken.Carter@soundunited.com for amplifier schematic requests.
  • mpitogo
    mpitogo Posts: 516
    Everything is glued down Giving up.
  • mpitogo
    mpitogo Posts: 516
    I contacted support and have a ticket open explaining the issue. Will try this route first.
  • mpitogo
    mpitogo Posts: 516
    Well I think she finally kicked the bucket. Won’t power on at all. Checking the fuse but I doubt it.
  • mpitogo
    mpitogo Posts: 516
    In case there is any interest, I found this service center.
  • Where are you located?
  • mpitogo
    mpitogo Posts: 516
    @EndersShadow Northern New Jersey
  • mpitogo
    mpitogo Posts: 516
    I ordered the repair and a 1 year extended warranty.
  • mpitogo wrote: »
    What was the price of the repair if you don't mind me asking?
  • mpitogo
    mpitogo Posts: 516
    Repair for DSW microPR0 3000 which includes 90 days warranty $175
    1 year extended warranty $45
    Return shipping $15
    In all not bad considering subwoofer replacements can be pricey for the specs. While the sub is a diminutive little box, it really packs a punch, 1000W RMS 2000 peak. And I run dual identical subs each independently measured by Audyssey multieq.
    Finding a replacement to fit the space is extremely difficult. The end result is small sub with similar dimensions and sub par performance, many out there or pricier subs with similar dimensions and performance eg JL Audio E-sub e110 $1699ea or better performing Velodyne DIgital Drive Plus 10 $3299ea.
    Hoping I can get at least another year with the pair, been maybe ~10 already. Yes I know SVS and HSU and REL exists but their subs and get rather large and heavy.
  • Thanks for the info. These don't come up for sal too often but good to know just in case.
  • mpitogo
    mpitogo Posts: 516
    Polk support must be very busy, just got a response 9 days after opening a ticket. I was asking for how much a replacement amp would cost and they sent me what looks to be a standard response. For one my sub is well past warranty and second even if I wanted to there is no way I will be able to find the receipt or CC statement.
    From Polk support
    In order to properly process your inquiry, please provide the following information:
    A copy of the original purchase receipt or credit card statement showing the purchase date of your product;
    Your shipping address;
    The serial number for your product
  • _nerd
    _nerd Posts: 54
    Wow you found a place that could service this amp? I bought my 3000 with a dead amp for $100 and when I called Polk to get a repair quote, they called a couple placed while I was on hold with them, and nobody would touch my amp. So I bought a brand new amp with a 3-year warranty direct from Polk for $300, shipped from their Vista, CA facility.
  • teddie105
    teddie105 Posts: 1
    I have a 2000 and Vista just sent me a 3000 board for 200 bucks so I’m going to try it
  • mpitogo
    mpitogo Posts: 516
    My other (I have two) 3000 kicked the bucket. Does anyone know the failure mode of these plate amps? Any suitable replacements?
