sub wiring, line level vs. speaker level
rossman
rossman Posts: 1
I recently purchased the RM6750 Polk system. This system also came with the Yamaha RX-V450 AVR. In the "RM Theather Setup Guide" it says to connect the sub via speaker inputs. Then set the front speakers to sml and Bassout to front, thus giving the full range of sound to the sub. It claims this will give the sub its best performance. Is this true? Is there really an advantage hooking the sub up this way vs. using a sub cable and the AVR sub out to sub line in? Thanks for the help....
Mark
Post edited by rossman on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited December 2004
    It all depends on the AVR being used. If you have an AVR with the sub output I would use that setup over the speaker input on the sub. With the sub output on the AVR you are using the bass management of the receiver vs. the balance of sub setting the front speaker’s volume.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
