sub wiring, line level vs. speaker level
rossman
I recently purchased the RM6750 Polk system. This system also came with the Yamaha RX-V450 AVR. In the "RM Theather Setup Guide" it says to connect the sub via speaker inputs. Then set the front speakers to sml and Bassout to front, thus giving the full range of sound to the sub. It claims this will give the sub its best performance. Is this true? Is there really an advantage hooking the sub up this way vs. using a sub cable and the AVR sub out to sub line in? Thanks for the help....
Mark
Mark
Post edited by rossman on
It all depends on the AVR being used. If you have an AVR with the sub output I would use that setup over the speaker input on the sub. With the sub output on the AVR you are using the bass management of the receiver vs. the balance of sub setting the front speakers volume.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
