Woofer stuck in standby psw505
smith365
Hello,
My 2 year old subwoofer stays in standby mode(red light). I tried hooking up a different reciever and wired it via speaker wire instead of the rca input. It stays with the red light on. Any ideas? Thanks
Have you tried the "always on" position to eliminate the auto detect feature?
Yes, I have flipped the switch to any of the three positions and still no change in the red light or bass from the speaker.
Hello,
It would be best to contact Polk at 1-800-377-7655 select option 1 and have the serial number when you call. -
OK I called and they are sending me a replacement amp. When they email you with the information needed( Serial # invoice etc) do you just reply to that email with the information? Will a screen shot of the email invoice from Newegg suffice?
Thanks -
I believe that would be correct.
Ok Thanks I will let you know if the replacement part solves the SW problem.
Polk sent me the replacement amp and the woofer fired right up find. I hope the replacement part doesn't have the same life as the old. Thanks for your help
