Do bigger magnets automatically mean better?
Dabutcher
Dabutcher Posts: 2,604
edited September 2018 in Speakers
Auto forum seems dead? I am sound deadening four door panels. Stock JBL’s are eleven years old. So I bought Polk MM1 ‘s to replace them. Thinking it’s an upgrade. But magnets on Polks are almost nonexistent compared to JBL’s. Have not tried them out yet. Thanks. D
    VR3 Posts: 29,427
    Looks like Polk is using neo versus jbl is ferrite
  • Dabutcher
    Is that good or bad? Thanks. D
    VR3 Posts: 29,427
    Neodium magnets are stronger in a smaller package
    treitz3 Posts: 19,992
    Simply put? No.
    VR3 Posts: 29,427
    Stop with your short but sweet answers
    - Not Tom
    Shut up Trey.
    LOL
    VR3 Posts: 29,427
    Make me
    - Not Tom
  • Unless you want to get into motor design, Thiel/Small parameters, and enclosure design, you won't know much about a speaker just by looking at the magnet. What matters is: how does it sound to you?
    Cheers, Jim
    A day without music is like a day without food.
    Viking64 Posts: 7,552
    Cheers, Jim
    Cheers.
    -Jim
    VR3 Posts: 29,427
    See what Tom started
    - Not Tom or Jim
    Magnets. How do they work?
    mhardy6647 Posts: 35,014
    Does the amplifier with the most watts win? ;)
    The biggest and/or heaviest magnet doesn't necessarily mean the best driver.
    This is especially true with the growing popularity of extremly lightweight and powerful magnet made of (typically) neodymium. Neodymium magnets can be very strong while also being very small and lightweight, which is kind of disconcerting.
    https://www.parts-express.com/bc-18ds115-18-professional-neodymium-subwoofer-8-ohm--294-6026
    Now, this being said - depending upon the type of enclosure design desired, by and large a strong motor (typically, low Qts) is often desirable, and a strong motor generally means a strong magnet. The flux density and shape of the magnetic field are the kinds of paramaters that are important for the performance of a driver. The overarching goal is linear drive of the cone within its designed excursion limits.
    It's like, technology and engineering and materials science and stuff, man...
  • laelle
    laelle Posts: 100
    Neodymium magnets indeed are very good not only do they pack a punch, they are very even frequency wise...
    They even make Q-Tuner pickups made of neodymium magnets for guitar and bass... really awesome
    Those who look at this and think about magnets?
    Seriously......look up direct servo. You can thank me later.
    Tom (the ACTUAL Tom)
    ZLTFUL wrote: »
    AlNiCo also comes to mind...smaller magnets but in most cases, superior.
    Yes and no :) There are some pretty beefy AlNiCos out there, old and new (as you know) JBL, Altec and good ol' Lowther all kinda spring to mind :)
    any driver that has its own handle(s) is probably a worthy one. B)
  • Emlyn
    Emlyn Posts: 4,708
    laelle wrote: »
    Out of curiosoty, I bought a little sleeve of button sized neodymium magnets a couple years ago. The strength of those things is shocking for their size. Especially when two of the magnets jump together and catch some finger skin between them.
  • laelle
    laelle Posts: 100
    Emlyn wrote: »
    laelle wrote: »
    Hahahah absolutely... they are so strong some say they have spiritual properties, like orgone pyramids
  • mlistens03
    mlistens03 Posts: 2,767
    I like neodymium magnets more, just because they are lighter and about as strong, if not stronger.
    I will say that there are some speakers out there with very small ferrite magnets (my Infinities had pretty small ferrite magnets) and they were very nice. Solid, clear bass, defined mids and highs. If you placed them right, they had more bass than the LSi’s.
    Basically, great speakers, with fairly small magnets. Once again, doesn’t matter too much.
    Not Tom, or Jim, or Trey, just Micah
  • mlistens03 wrote: »
    VR3 Posts: 29,427
    You guys....
    Not Tom, or Jim, or Micah, or Ken
    Tony M Posts: 11,623
    Betsy huh? I dated a Betsy for a while. :|
  • warren
    warren Posts: 756
    I blow thru here
    The music goes 'round and around
    Whoa-ho-ho-ho-ho-ho
    And it comes out here
    I push the first valve down
    The music goes down and around
    Whoa-ho-ho-ho-ho-ho
    I push the middle valve down
    The music goes down around below
    Below, below, deedle-dee-ho-ho-ho
    Listen to the jazz come out
    I push the other valve down
    Whoa-ho-ho-ho-ho-ho
    And it comes out here...
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
    SCompRacer Posts: 9,112
    It's a matter of Gauss.
  • All I know is when I got my OHM model L- after pulling the drivers I found what I thought to be the heaviest/largest magnets in a book ender. I didn't weight the things but I was surprised and sorry they left town because they were that good. Maybe I'll e-mail Evan today to ask what they weigh and why.
    The classic Altec Duplexes employ large and heavy (i.e, powerful) AlNiCo magnets for both the woofer & treble drivers. The high magnetic field and high flux density of these drivers is used to afford high sensitivity as well as high linearity. Sensitivity has rather fallen out of favor as a design criterion for loudspeakers, since watts are dirt cheap any more. :(
    The Altec woofers (like their contemporary drivers from JBL) were low-excursion drivers with huge (3 to 4 inch) but shallow voice coils -- very different than the current fashion in woofer design.
    The treble (compression) drivers likewise used large diameter VCs and truly massive AlNiCo magnets. The JBL 2441 treble drivers I am currently using weigh about 25 lbs
    each. Not all of that's magnet, of course, but the magnets in 'em are pretty beefy.
    39958549212_fab98689d5_h.jpgDSC_0457 (3) by Mark Hardy, on Flickr
    JBL 275 on the left; 2441 on the right, 2A3 direct-heated power triode :) for scale.
    Nerdy aside: "Gauss" as a unit of magnetic flux density has been superceded in the SI system with units of "Tesla" (T). One Gauss equals 1×10−4 Tesla (100 μT), so 1 Tesla = 10,000 Gauss.
  • I did mail Ohm and they came back very quick w/ a response..
    Ohm Acoustics ohmspeakers@aol.comHide
    To lewdworet lewdworet@aim.com
    Hi Lewis,
    The Ohm L magnet weighted 32 oz. and the iron parts were extra thick to reduce 'magnetic resistance'.
    IMHO, Neo is the best for tweeter (for small size); Neo or big ceramic are best for mids (when size is not critical) and woofers and big ceramics are best for subwoofers where heat sinking is most important).
    Good Listening!
    John
    Ohm Acoustics Corp.
    76 Degraw Street
    Brooklyn NY 11231
    800-783-1553
    https://ohmspeaker.com/speakers/
    :( Yeah, huh?
    Amusingly enough -- I asked again over at hifihaven & got a couple of good suggestions (brass putty knife being one, differential cooling - or heating - being another). I will tackle 'em one of these days with the some empathetic help from one of the local gurus. This summer was way more complicated than expected, given Mrs. H's eye problems (and travel) :(
    http://www.hifihaven.org/index.php?threads/so-i-have-an-interesting-problem-challenge-opportunity-a-stuck-horn.3930/
