pixiedriver
pixiedriver
How do I gain access to cross over components in a very old Monitor 10, Ser No. 0074,
I can't seem to find anything removable in the back panel where the fuse and wire lugs are.
Best Answers
Take out the passive radiator.
Take pictures of the crossover from that opening & the back of the speaker.
Post them here & advice will follow. -
0074.
wow.
pixiedriver wrote: »Was hoping to avoid that process But I guess not. T.Y.
Understood. But sometimes you have to do what you have to do to get the correct information.
I'll bet plenty that you'll find the crossover is hand built on a breadboard.
Hence Mark's "wow" -
And more than likely used mortite for gasket material. That stuff is like glue be very careful
pixiedriver wrote: »They also have the industrial velcro grill attachers, I'll send pic's of those too.
Supervelcro
P1020559 by Mark Hardy, on Flickr
The tags are gone off of the old pair of 10s here, so I don't know the s/n.
Answers
identical
