Just cuz...
jdjohn
Well, my PS Audio S300 power amp has two pair of speaker outputs, so why not add a fresh pair of Baby Advent II into the mix?
Infinity RSIIIa with these Advents...fun
And just cuz...inverting the Baby Advents makes it even better
Beautiful pair of vintage awesomeness by Infinity. Be careful not to f em up with those little ones. Peace. DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Shakes head......Political Correctness'.........defined
President of Club Polk -
Are you playing both pairs of speakers at the same time?
i'm thinking the two sets of terminals are meant for bi-wiring, if the intent was for multiple set of speakers they would include switching on the front of the amp.
i would be very careful of the impedance of the speakers you hook up.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
... a stacker... I'm kinda with @F1nut on this one.
Unfortunately, this phenomenon has a real historical precedent.
The Absolute Sound.
source: http://www.classicspeakerpages.net/IP.Board/index.php?/topic/5746-stacked-advents-as-reviewed-by-the-absolute-sound-magazine/
And, in all fairness, Mark Levinson (the actual ML, not just the company that had his name after he divested himself of it) did it too... but at least he stacked Quad ESL-57s
(borrowed image, of course)
In fairness (and seriousness), the Baby Advent II actually aren't bad little loudspeakers. Have you refreshed the crossovers in 'em? Decent-quality modern capacitors yield a marked improvement in transparency (for lack of a better word) IME.
123 by Mark Hardy, on Flickr
I was just kind of goofing around with this...had been wanting to try it for awhile. There are four pair of binding posts on the back of the amp (I mistakenly said two pair earlier), but marv is probably right that it is for bi-wiring. The Infinitys are 4-8 ohm, and the Baby Advents are 6 ohm, so both in the same range. I didn't turn it up very loud (it was late), and obviously it looks a little obnoxious, so this setup won't stay.
Mark, thanks for the tip on the crossovers. I'll definitely check that out since it should be a simple replacement. I've already re-foamed the woofer surrounds. They do sound pretty darn good as sealed bookies."This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
I suppose it could be worse.......you could stack some sda's
motorstereo wrote: »I suppose it could be worse.......you could stack some sda's
I did just that with the SDA-SRS2's and SDA-CRS's. They are the same size. I did not play both at the same time though. If my SRS2's were the 8 ohm versions, maybe I would've. Maybe just for a volume experiment.
But... but... stacking SDAs!?
Think of the waveform interference patterns?!
Think of the energy!!
It'd be like... like... crossing the streams!?!
Wouldn't it?
[/quote]
I had separate amps for each pair of sda's so I was able to and did play both pair at the same time. I look at that experiment now as just another mistake made while headed down the audio trail. -
I actually did that with my old 2.3 and 1.2 side by side hooked up to 2 different sunfire amps but, I did not have the sda cable in. I will say it moved quite a bit of air!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
