Audio nuggets YOU have learned along the way...
  • Joey_V
    Joey_V Posts: 8,603
    edited August 2018
    1. There's definitely a point of diminishing returns.
    2. Room beats all.
  • Willow
    Willow Posts: 11,365
    Better to ask for forgiveness than permission.
  • kharp1
    kharp1 Posts: 3,453
    edited August 2018
    Tony M wrote: »
    verb wrote: »
    All good advice @Tony M I’ve got an SAE amp that’s been sitting in the box for years. Eventually I want to use it for my garage setup. Any startup advice?
    Use cheap speakers to start with. I hope it starts working from the get-go. SAE gear is pretty good aren't they?
    Start with a variac. Do not use without hooking it up to a variac.
  • machone
    machone Posts: 1,588
    Hot glass looks like cold glass :#
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • decal
    decal Posts: 3,205
    Quit obsessing over this stuff. Have fun, enjoy the music.
    Tony M Posts: 12,017
    kharp1 wrote: »
    Tony M wrote: »
    verb wrote: »
    Most of us don't have a Variac. I did think about that but didn't include it in my response to Dave's question. You're right. Maybe I should have.
    Dave might own one. ;)
  • gp4jesus
    gp4jesus Posts: 2,021
    edited August 2018
    1. Bigger speaker wire.
    2. I’ve often been surprised at the results of upgrading to bigger internal speaker to mid-bass & especially woofers. Further it’s practically a free performance improver.
    3. Dedicated multiple higher current power feeds.
    4. Heavier power cords
    5. Active power conditioning - all around for video & sound quality.
    *all connected w/Premiere ICs
    VR3 Posts: 29,750
    It's all in the source.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Wattage ratings are often misleading. Current ratings are less misleading.
    Garage | Polk Monitor 5B's
    EndersShadow Posts: 17,759
    NEVER, EVER allow anyone to carry your prized Tyler Lindbrook speakers down a flight of stairs. I wish I could find that picture....
    @treitz3
    mhardy6647 Posts: 35,562
    machone wrote: »
    Metal tubes are even worse in that regard :/
  • Willow
    Don't peruse the fm section after having a few drinks. Heck any audio selling site for that matter.
    Tony M wrote: »
    kharp1 wrote: »
    Tony M wrote: »
    verb wrote: »
    WARNING, WARNING! THREAD CAREENING TEMPORARILY OFF-TOPIC!
    If you don't feel like buying a Variac, you can make one (or a reasonable facsimile thereof) with parts you can (still) get at your nearest Home Despot or Lowes or even local hardware/electrical supply store (if you're lucky enough to have one).
    Google "Dim bulb tester" for instructions & info.
    Here's one example, to get you started :)
    https://antiqueradio.org/dimbulb.htm
    The goal with these devices, by the way, is to ease the components back to life rather than slamming them with AC mains voltage & wakin' 'em up with a jolt. The DBT can also help diagnose problems (short circuits, e.g., in the power supply or even downstream of it) without toasting fragile and sometimes expensive components inside the device being tested/reawakened.
    This is (FWIW) more of a must-have for vacuum tube hardware (with high voltage power supplies) than for solid state stuff, but on the other hand, the use
    of solid-state rectification in any component
    The main idea is to use lower input voltage to reform the component's electrolytic capacitors, particularly the "filter" caps in the power supply. This is, at the least, a do no harm exercise, and can rescue capacitors that might otherwise be (more or less) toasted by a hard start up.
    This said, electrolytic capacitors are pretty brute force solutions to a couple of problems (the need for large values of capacitance at high-ish voltages, in a compact package and cheap). Two factoids (strongly held opinions, empirically informed) about electrolytics. 1) any that are more than about three decades old have outlived their usefulness and should probably be replaced and 2) the ones you can buy today really are better than the ones you got three, four, or more decades ago.
    Just sayin'.
    OK IT'S SAFE TO RETURN TO THE THREAD NOW. MOVE ALONG, NOTHING TO SEE HERE.
    SCompRacer Posts: 9,399
    Upgrading audio is like making love in the sand. You don't want to stop, but you have to.
    Eventually you may reach a point where you say I can't afford or don't want to afford upgrades.
  • codycatalist
    codycatalist Posts: 2,661
    1. Take your time, don't buy whatever you can find. Wait for the right piece for you at the right price, it will save you money down the line.
    2. Vintage gear is cool but chances are you will pay just as much if not more than the asking price to get it working like it should.
  • tonyp063
    tonyp063 Posts: 1,157
    Trust your own ears.
    Clipdat Posts: 13,104
    edited August 2018
    Attend an audio show if you haven't ever been to one.
  • Willow
    Its OK to make mistakes just don't repeat the same one over and over.
    Willow wrote: »
    N.B. This aphorism may be provisional in the case of mistakes made working on vacuum tube amplifier high-voltage power supplies
    In those cases, there may not be an opportunity to repeat the mistake.
  • steveinaz
    steveinaz Posts: 19,546
    edited August 2018
    I have another one, and it's a biggie...
    Better to cry once, then cry TWICE. Don't let excitement rush a purchase of a lesser item, because you don't have the money at the moment for what you REALLY want.
    I don't want to even know how many tens of thousands of dollars I have wasted, "settling" on a lesser item that I later sold at great loss. I am embarrassing myself for YOUR educational/monetary benefit. You are Welcome.
    Make sure your Pos. and Neg. wires are hooked up to their proper outputs and inputs.
  • steveinaz
    edited August 2018
    Check your speaker driver mount screws, you'll be shocked how loose some of them are. Make it an annual thing.
    Buy some ty-wraps and do some cable management; it lower your noise floor. Keep IC's away from digital, and AC away from everything.
  • mrbiron
    mrbiron Posts: 5,721
    Beer makes music sound better.
    heiney9 Posts: 25,710
    Tube gear isn't as finicky as people want to think.
    Wattage isn't the major factor in determining a good amplifier.
    Best listening enjoyment is found in the sweet spot
    Everything matters.
    Those that don't know, don't know that they don't know.
    Very few giant killers truly exist, despite hubris stating otherwise.
  • Willow
    mrbiron wrote: »
    Music makes beer taste better.
  • erniejade
    erniejade Posts: 6,327
    The more you drink the better I look
  • lightman1
    lightman1 Posts: 10,802
    erniejade wrote: »
    And your getting darn near sexy at your B-day party.....
