Polk Audio CRS + (RDO198) Crossover Modification Thread
Thank you Dave, The dread naught is perfect -
Home Theater/2 Channel:
dhsspeakerservice.com/ -
I contemplated only cutting holes for the internal connections leaving finger room to unclip but by the time i did the drawing template i really didnt cut out that much more than what was needed.
I have had drammas with overlapping materials with my SRS and more seals or glue would have most likely been needed between them.
The plates that the crossovers are attached too are extremely solid and well braced .I added a little dynomatt internally where possible(3 square "s max ech".
It reminds me of the SDA SRS-1.2 plate.
I wouldn't add braces to the front bezel but if it was originally braced i would definately check and add extra glue,re glueing my braces and Larry's rings in my 2 X SRS'S in my theatre lowered my noise floor and added more depth and air.
SDA CRS 4.1 TL 20 hrs in and they sound amazing. -
Extremely nice work by everybody involved in this Awesome Project, wish I could have a seat in the Sweet Spot!
I highly recommend Dave and Trey's handy work and lets not forget of all the shared knowledge through this great site which i have been stalking for many moons now.
what can i say.......24 hrs playing and triple wowsa ,i am so surprised ,these little monsters are already surpassing my expectations .....
burn in with a little sunfire 17" 5 x 225 channel, mitt cvt terminator 1's to current top end and voltage to lower end via transparent reference mm fed by a little sonos connect ,i guees i should hit 500 hrs in 20 more days
then oppo105D modded by Mr Joe Rasmussen takes over dac duty .
ohhh,i forgot to also thank Larry,who within a nites notice supplied the last remaining set of rings he had for my CRS when i asked in the forum around 7 months ago.
Thank you Larry ,i would never build a set of polks with out your rings, these put them up on another level instantly!
cheers Mate -
Glad to hear they are opening up nicely.
Ive been very impressed with the cmr... Same level of detail of the Mr but a hint warmer- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I have to say that was a ballsy mod cutting that hole in the cabinets, they look awesome, and there is no copyright on my speaker stands, or rings for that matter, if one has the means to build them, build them!! I’m not one to get **** because someone copied an idea, it’s a hobby, and these speakers are how old? 30 years?
The stands look great, along with the crossovers, I love the braided speaker cables..
Enjoy..
Thanks mate, all fun , It was just some harmless banta and Your absolutely correct ,It was a hard decision cutting them out , im glad I did they were a little Fidely installing the washers ,nut and locking nut ,not much room within these little babies but I can certainly say they gained a little weight
Sean did a great job on the install.
Larry if your comment is towards me, feel free to PM me.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It was not directed to you, but looking at it I can see why it came across that way, my apologies..
That hatchet was buried a long time ago, well I would like to think so..
Yep thought so to lol- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
love the pic
Enjoy..
in case any one is wondering...the circles are the bare minimum needed to have installed these
xovers -
Those bad boys do take some. Real estate- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
They sound incredible thanks Trey....I'd do it all over again no problem!
Try flipping the passive if you think you may have lost a some internal volume with your new mods.Don't take experimental gene therapies from known eugenicists.
350 hours and all positive , cheers. Thanks for the tip
How's it sounding Sean- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
No complaints here. Must be 600 hrs in and my wife and self cant help notice how the notes just really sound really so natural. Thanks again Trey. ❤️
To be quite honest Trey,theres not a song that goes by where my attention isn't drawn to how pleasing they sound.
I have been playing them quit allot recently for background listening and i love the fact that i can still feel them. ..... I Likem allot : ) they'r keepers.
That's awesome. Sometimes smaller speakers are easier to dial in to the room
Glad to hear 😊- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Glad to hear 😊
Agreed, there are things my CRS+’s do that I wish my 1.2tl’s did in my room..
Like what?Proud and loyal citizen of the Digital Domain and Solid State Country! -
Sean @ptrooper How are the CRS's doing?
gidday@honestaquarian The CRS's and SRS's in the theatre room just keep getting better with every upgrade i put in front of them : )
Thanks Trey
And Merry Xmas .
Glad to hear they are rocking out!
Merry Christmas guys!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
That looks sweet. Very creative Trey! Bet it sounds good too."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Thank you sir! 😊- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
