Tidal hifi streaming
So I just signed up for the 30 day trial and did some a/b testing back and forth with Apple Music. Quite a difference in audio quality. Will see if I actually get use out of it as the wife loves the seamless integration of Apple Music into our cars and phones, but as I type this I am listening to Tori Amos and and thinking I need to stop buying CD’s for a while and enjoy this service.
Any of you have this and have you compared with other streaming services and have anything to add?
SPEAKERS - ELAC ADANTE AF-61, TOTEM RAINMAKER, SONUS FABER SOLO, DEFINITIVE TECH SM350, MIRAGE OASIS, SONOS PLAY 5 & 1'S, SVS SB16 ULTRA
POWER - PS AUDIO M700, LINN LK240, MARANTZ SR5013
PRE/DACS - PS AUDIO STELLAR GAIN, CAMBRIDGE AUDIO CXN V2
SOURCE - DENON 2910, SONY CDX355, JVC XM448, REGA P2 (MODDED) ANIA CART, REGA FONO MC, XBOX 1 S, TIVO BOLT
POWER/WIRES - AQ NIAGARA 5000, AQ HURRICANE HC (2M), AQ MONSOON HC (2M) , AQ COLORADO XLR (2M & 1M) AND RCAs(1M), AQ VICTORIA(1M), ACOUSTIC ZEN SATORI W JUMPERS(3M), ATLAS EOS PC, WW STRATUS X3/AURORA X1 PC, AQ CARBON HDMIs
MISC- OKKI NOKKI RCM, HARMONY ELITE, SONY 75XBR900E
  • DSkipDSkip Posts: 15,666
    It's the only way I listen to music anymore. Keep in mind if you are listening through a computer that a streamer will elevate the sound even more.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • Mikey081057Mikey081057 Posts: 6,161
    I use Tidal with Streaming Devices and a solid state PC and DAC. I've added a Chromecast Audio device as well. Certainly the best SQ and convenience option in audio. You can make up some great playlists like they were mix tapes B) B)
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7704 | Sunfire TGA-7401 | Oppo UDP 203 | Sony PS4 Pro| Directv Genie HD DVR | Samsung 75" Q8 QLED | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A21 | Parsound Halo A52+ | Marantz AV7002 AV PrePro | Usher Dancer Mini-x DMD's | Usher BE-616 Center | SVS Ultra Surrounds | SVS SB4000 Sub |Oppo UDP 203 | MIT Shotgun S3's | PSAudio Stellar GCD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | Lumin U1 Mini | HP Elite Slice PC | ROON'd for life | Samsung 50" SUHD TV | Sony PS4
    Patio Polk Atrium 8's | Yamaha R-N303BL |
    Office Bluesound Node | Polk SDA SRS 2.3 | Marantz 2385 |
    Bedroom Peactree Nova 125SE | Focal 905's | Chromecast Audio | SVS SB2000 Sub
    Garage Yamaha R-N303BL | Polk Monitor 5B's
    Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | 2 Parasound A23's | Marantz 2252B
  • joecoulsonjoecoulson Posts: 2,562
    I just have the Sonos connect which I know is no where near the best but it’s what I have currently. I have it connected to the Pre using toslink. So at least I am using the Marantz DAC and not the Sonos one.
    I would like to get a pro streamer, just not sure if I wanna drop $1500-3k on one. Not sure if the bluesound node 2 is worth $500 or if it will be a glorified Sonos.
    If you are part of the Apple infrastructure look for a used AURALiC Aries Mini. They were and still are the best streamer under $500. At any rate, the Sonos is much improved over a PC.
    audiothesis.com/
    Cabling: Wireworld
    So that brings up a question I cannot seem to answer, is there much of a difference between that mini and the bluesound IF I am send the signal to a sep DAC? Would there be much difference in those from the Sonos for that matter? I get the DAC’s would make the most impact downstream, but is there that much of a difference in the way 1’s and 0’s are handled?
    Yes. This is not projected at you, but I really wish people would stop the '1s and 0s' argument. There is much more in that signal than just the data, and part of that is the noise generated from the transport (in this case, the streamer).
    I would suggest doing a google search on the Node vs. the Mini.
    I currently use a Mini for my main digital transport but do have an Aries G1 en route. I'm excited to get this one in.
    audiothesis.com/
    Cabling: Wireworld
    Any thoughts on the Cambridge CXN v2?
    And no offense taken, will google the comparisons
    Actually, no. I haven't had the opportunity to deal with one yet. I also haven't heard from anyone who I trust that has.
    audiothesis.com/
    Cabling: Wireworld
  • rooftop59rooftop59 Posts: 5,342
    Love tidal! Use both a Bryston BDP-1 and a little NUC computer and while the bryston is definitely superior, the computer works great for causal listening and sounds really decent unless you are really listening critically, which I almost never am in the family room.
    I’ve bought maybe 5 cds in the last year...
    The next step is Roon, definitely takes it to the next level especially if your library is digitized.
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio NovaPre; B&K TX4430; Bryson BPD-1; Mains: Dynaudio Emit 10; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - HSU VTF-2 MK5; LG UP870 4K BDP; NVidia ShieldTV
    Master Bedroom
    Marantz SR-5007; Parasound HCA-1000A, PSB Imagine B, NHT Super One CI surrounds, Martin Logan Dynamo (original), Squeezebox Touch
  • DerfDerf Posts: 202
    @DSkip set me up with an Aries mini and North Star Supremo DAC which I use to stream Tidal. I really like the service. I added a Marantz SA8004 just because I wanted to try out SACDs. Bought Santana’s “Abraxas” from MOFI. Tidal stream of the same album gives slightly more detail.
    Integrated Amp: Marantz PM-10
    Speakers: Usher MD2
    Subwoofer: Rythmik F15HP
    DAC: North Star Design Supremo
    Streaming Source: AURALiC Aries Mini
    SACD Player: Marantz SA8004
    Power Source: PS Audio PP3 on dedicated 20amp circuit
    Skip is your experience with the Node or the Node2 ? Important to note that the Mini is an end of life product and only integrates with IOS where the Bluesound products integrate with IOS Android Windows MAC Chrome OS and receives many updates and excellent support as a current product. I would be curious to do a comparison with Fred's mini /North Star rig vs my Node2 Mytek Brooklyn DAC+.
    Maybe we can meet up after Hurricane season Fred?
    edited August 2018
    Ears I trust say the Node 2 still doesn't best the Aries Mini. I fully see your points and those weren't factored into my opinion - only performance was. Up to this point, all updates have been applicable to any AURALiC product though so it is still supported.
    I SHOULD be more on top of this, but I do know that AURALiC has developed a web-based 'remote' as well. I haven't played around with it yet but might give it a go on my PC when I get the G1 in. Also, it is able to be controlled by ROON now - so there is that.
    The reality is that AURALiC probably made no money on the Mini and treated it like a loss-leader. It is definitely a product that offered much more than its modest $500 price tag suggested. Even after they were discontinued, I bought nightfall's Mini so I could have another one around. It really is the definitive entry-level streaming device as long as owning Apple isn't an issue for you.
    I know most of you are aware I am an AURALiC dealer and honestly, that doesn't sway my opinion. The Mini is discontinued so there is no point in talking it up from a dealer stance anyways. I sold the last three that were imported to the US and was completely disheartened when they ceased production.
    audiothesis.com/
    Cabling: Wireworld
    Sounds good, Mike. Look forward to it!
    Speakers: Usher MD2
  • txcoastal1txcoastal1 Posts: 10,292
    Derf wrote: »
    Let me know when this may happen :)
    You coming to SW FL Ronnie?
    edited August 2018
    If timing right I'll puddle jump from Pensacola to Tampa area for $250
    Just need 3 weeks notice
    In the future may have a Buc-ee's coming to your area. There are 4 on the schedule, only disclosed are Daytona and St Johns
    Cool but we are closer to Fort Myers... Tampa is about 2 hours north of me and about 3.5 hours north of Fred...
    Nevermind there are no non stops.... we will work it out
    Driving 2hrs for me is like most people driving 30min...can do a lot of business on the ground :)
    This is my route this Thursday and Friday
  • tonybtonyb Posts: 30,901
    txcoastal1 wrote: »
    Yeah, we know. You and Tom have a lot in common it appears. :p :p :D :D
    HT SYSTEM-2 channel
    Dynaudio Audience 72
    Cary xciter dac
    Cullen modded Sonos
    Joule la-100 pre
    B&k Ref 4420 amp
    Analysis plus crystal oval ic's
    B&k 1430
    Tad 803 speakers
    tonyb wrote: »
    txcoastal1 wrote: »
    hey now, you're the one with pics on your cell phone :p
    txcoastal1 wrote: »
    Sounds like we’re getting a party started!
    Speakers: Usher MD2
    They're not just on his phone the NSA has them too!!!
    I might be able to ship a little something something for you guys to play around with.
    audiothesis.com/
    Cabling: Wireworld
    Intriguing B)
    Skip. Was trying to locate that Aries mini to no avail. Any ideas on where to find?
    Music Direct might still have some in stock but other than that you’ll have to find used units.
    audiothesis.com/
    Cabling: Wireworld
  • The mini is hands down one of the best audio purchases I have made over the last couple years. Easy to use, sounds great a lot of bang for the buck. Worth waiting for on the used market.
    Living Room
    Yamaha Aventage RX-A 1060, Parasound P5, Parasound A23, Yamaha BD-S681, Auralic Aries Mini, Polk S60, Polk S30, Samsung 60" LED
    Office
    B&K Ref 50, B&K 200.2, Chromecast, LSiM 703s
    Douglas Connection ICs and Cables
  • Rich502Rich502 Posts: 105
    I agree, can’t believe I didn’t pick one up when they were still making them. Now to find an alternate, that does the same thing, even if slightly more money.
  • steveinazsteveinaz Posts: 18,929
    Does Tidal have like a radio function where you can just tell it you want classic rock, and it will play songs? Like Pandora?
    Source: Bluesound Node 2i | Preamp/DAC: PS Audio Stellar Gain Cell | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable Analog 2 XLR; Kimber 8VS Bi-Wire; DH Labs D-75 Dig Coax | AC Power: Panamax M5300-PM
Howdy, Stranger!
