USB to SPDIF Converters?
msg
msg Posts: 10,472
I saw a couple of threads a while back about USB to SPDIF converters, and the Peachtree X1 and Musical Fidelity V-LINK seemed to be good overall options for quality/cost. I have a couple of old DACs that don't offer USB that I'd like to check out with computer audio.
I think iFi makes one as well, the iLink.
Anyone else using one of these converters other than the aforementioned, and getting good results?
  • machone
    machone Posts: 1,566
    edited July 2018
    M2 Tech HiFace Two was recommended to me by Benjamin of Mojo Audio.
    I have no personal experience with this device but he knows digital.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    msg Posts: 10,472
    Thanks, man. Yeah, that M2TECH HiFace stuff keeps popping up in my reading, mostly just casual at this point. Probably need to dive into the research a little deeper.
    Seems an overlooked/obsolete segment these days as a lot of people have moved on to more advanced DACs that already have a USB option.
    There are lots of cheap options out there, but I get the sense that going that route will probably destroy the benefits I think USB's offering.
    Clipdat Posts: 13,100
    Topping D10 is 20% off for Prime Day and it does USB in -> Coax/Optical out.
    https://www.amazon.com/TOPPING-Dilvpoetry-es9018k2m-opa2134-Amplifier/dp/B07B46KQVP/
