Conrad Johnson vs. Carver Amp
124»
    edited March 2018
    Glad you like it, but many of us knew the outcome ahead of time. Now when you hear someone say that amps don't matter much, you have a frame of reference to prove them wrong.
    Older higher end pieces make excellent audio choices for those on a budget. Congrats again.
    Oh, and get that amp off the carpet soon. Static isn't good for amps.
  • verb
    verb Posts: 10,176
    Will do @tonyb ! Thanks!
  • verb
    verb Posts: 10,176
    Not on my list of reference CD's but hey maybe I'll give it a go! Thanks Jimmy! :smiley:
    Viking64 Posts: 7,591
    verb wrote: »
    Yeah, the sound quality leaves a lot to be desired. :p
  • verb
    verb Posts: 10,176
    tonyb wrote: »
    Well I finally had a chance to make a stand for my CJ Amp. Prior to that, I just had it sitting on a scrap piece of maple butcher block. Even before that, yes it was sitting on the carpet!
    I used 1.5" oak butcher block, and found the 1/8" steel legs on-line, designed for a chair or couch. There are 4 mounting holes per leg which I secured with screws. The feet are threaded which allows adjustment. Eventually I will replace them with spikes.
    pitdogg2 Posts: 27,168
    Looking very good
    Clipdat Posts: 13,098
  • Manticore
    Manticore Posts: 408
    Sexy that wood is. Looks sturdy too.
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
    Design inspired by Tom Swift's spaceship. :)
  • verb
    verb Posts: 10,176
    Manticore wrote: »
    Yep. I can stand on it (~200 lbs) without any issue. :smile:
  • verb
    verb Posts: 10,176
    Viking64 wrote: »
    Kinda spacecraft looking, I'll admit. Heck, I just need a monoprice amp to launch this sucker into orbit! :smile:
  • DaveHo
    DaveHo Posts: 3,582
    verb wrote: »
    Leg source please? I like the looks of those a lot better than some others I've used in the past.
  • verb
    verb Posts: 10,176
  • halo
    halo Posts: 5,616
    Good looking amp Dave!!!
