Another SDA CRS, this time the +
cortico
Just got this CRS + pair, seems real wood veneer, but I’m not sure which iteration this is. Probably transitional because it still has the holes where the previous 2 tweeter versions had the blade/blade jack.
I am willing to upgrade it for the RD0198, never heard one before. All it takes is a 5.8uf cap across the 2.7ohm resistor, right?
Thanks for you guidance.
Post edited by cortico on
You'll have to plug that hole.
The TL schematic is posted here.Political Correctness'.........defined
President of Club Polk -
This ^^^^^, and the 2.7 ohm resistor is already there. You're shunting it with the 5.8uf Capacitor.
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Most definitely! I’ll plug the hole with two matching rubber plug caps.
I liked the way the blade / blade two tweeters version sounded, the dimensional tweeter was unplugged... I know diferente animal.
Courious about this.
ThanksYou'll have to plug that hole.
The TL schematic is posted here.westmassguy wrote: »
These sound sweet, very nice and mellow mid range. I toke a picture of a crossover. The stereo mid-bass is the 6510 and the dimensional 6511...
I measured resistance between meg and pos terminal I got different readings:
Left 4.9ohm
Right 5.8ohm
Ah! Found a loose inductor in one speaker... wow
That'll be the high one.Political Correctness'.........defined
Yeah I had a similar with the pair I bought.
http://forum.polkaudio.com/discussion/179087/picked-up-crs/p1 -
I have soldered the connections and replaced the ties, it's all well secured now.
Could a 5.6UF cap be used instead of 5.8UF on the TL mod? is just about 3.5% off.
If that 5.6uF is +/- 10% and it's -10% it's no longer 3.5% off.Political Correctness'.........defined
Nice find!
I have used Clarity ESA and Sonicaps Gen I on crossovers, both excellent.
For this project, I am thinking of Jantzen Superior for the tweeter and Jantzen Standard for the ones parallel with mid-bass drivers. Anyone used Jantzen caps on these Polks before?
