front height speakers - recommendation
French_guy
French_guy Posts: 338
Hi
Looking for front height speakers that are not too bulky, but still provide good (at least decent) sound effect?
I was thinking about the OWM3...Is this a good choice? Any other recommendations?
RTiA5 + CSiA4 + Jamo SW410E
Yamaha TSR-700 (equivalent to RX V6A)
No surround...yet
  • mlistens03
    mlistens03 Posts: 2,767
    Just as a thought, you could get one of those speakers that sits on top of your mains and reflects off the ceiling, I know Klipsch and SVS both make a set of those. If those would work, I’d look at the SVS option.
  • rooftop59
    rooftop59 Posts: 8,121
    In ceiling are a great option if you can swing it. Otherwise, the older M3s or M5s that are wedge shaped are MUCH better speakers than the OWM3s and the shape would be ideal. Obviously you will have to look on eBay and be patient...
    Game Room 5.1.4:
    Bedroom 2.1
  • French_guy
    You mean Polk M3s or M5s?
    No surround...yet
  • rooftop59
    edited June 2018
    Yes. Check eBay. Lots available. Make sure they have the brackets. I used them for my patio for years. Nice sound for the money with solid bass unlike the ones ur lookin at.
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    Exactly! That’s a good clean pair and sound SO much better than the newer thinner ones. I don’t know why they don’t go back to making them as atmos speakers...
    Game Room 5.1.4:
    Bedroom 2.1
  • French_guy
    edited February 2019
    Hi Rooftop59
    I think I found a nice pair of Polk Monitor "AW M3 Serie II" (apparently new in box) for something like $65 !
    Do you confirm they will sound nice for front height or surrounds?
    No surround...yet
  • rooftop59
    I think they will! But only one way to find out for sure!!
    Game Room 5.1.4:
    Bedroom 2.1
  • mantis
    mantis Posts: 17,378
    If you have other polk speakers under the LSI and LSIM line they will work just fine. For $65 I think they will do really fine. I have installed them many times back in the day and for the retail price then they where nice so.
    Dan
  • I have RTia5 and CSia4.............
    No surround...yet
  • I have RTia5 and CSIa4...............and I know everybody is saying to go for the CSIa6 by the way !!!
    No surround...yet
  • I have RTI a5 and CSia4.....
    No surround...yet
    No surround...yet
    No surround...yet
    No surround...yet
  • Ooops...........something went wrong
    Don't know why it said "Will be posted when approved" !!!
    So I didn't pay attention I posted several times the same post
    Sorry about that !
    No surround...yet
  • verb
    verb Posts: 10,176
    I have these. Polk 265RT in walls. Simple installation, and they blend in without obstuction! :smile:
  • How do you install such speakers in a wall that has insulation?
    No surround...yet
  • verb
    verb Posts: 10,176
    French_guy wrote: »
    If the insulation is soft, you can compress it. My wall were 6" thick, so there was plenty of room for them! :smile:
  • Did you mount them as surround?
    Not sure about the best placement for my surrounds (I don't have any yet) since the couch were I sit is against the back wall......!!!!
    No surround...yet
  • verb
    verb Posts: 10,176
    Actually they are for a 2 channel rig in the Living Room! The Mrs did not want to have any speakers in there! I have a subwoofer in the corner too! :smile:
    https://forum.polkaudio.com/discussion/181670/in-wall-speakers-worthy-of-music/p1
