LSiM 707s: 2.5-3 dB difference
alucidideaalucididea Posts: 113
edited June 2018 in Speakers
So I hooked up my new preamp and as I was listening and setting up, I’m hearing a solid difference in output between the 707s. When the balance is even, I’m clearly hearing the right channel higher. And even when I I shove the balance over 2.5-3 dB, they sound sort of even, but even the right still pushes more high frequencies. It’s driving me pretty crazy, truth be told.
I’m going to hook up a couple other sets to speakers to troubleshoot before I contact Polk. I’d rather not have to try and send one/either of them in, especially since both the boxes got relatively destroyed in shipping.
Is this sort of thing normal in production to have such a difference between units?
  • FestYboyFestYboy Posts: 3,699
    No, I'd be checking the bias on the preamp before condemning any speakers.
  • alucidideaalucididea Posts: 113
    edited June 2018
    FestYboy wrote: »
    No bias switches on either amp or preamp. NAD M22/M12
  • DSkipDSkip Posts: 16,115
    edited June 2018
    Check that all drivers are working properly. Also might not hurt to check polarity of each driver. The second part requires pulling drivers out so try another pair of speakers first to ensure it isn't the preamp. Actually, switch the speaker cables and see if the issue follows the channel or the speaker.
    Reading the first post (to me) indicates that this issue only presented itself after the preamp was installed. If this is wrong, please clarify.
  • tonybtonyb Posts: 31,438
    edited June 2018
    FestYboy wrote: »
    That's my take also.
    If the new pre is of substantial improvement over what you had been using, what your hearing may be just simply a better separation of instruments and imaging. Also placement of the speakers in relation to your listening position and room reflections can also give the illusion of one speaker being louder. I highly doubt it's the speakers.
    Check all your wire connections also.
    B&k 1430
    Tad 803 speakers
  • ClipdatClipdat Posts: 7,137
    Any updates?
    "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
    Clipdat wrote: »
    Any updates?
    Sorry, none yet. I’ve been a little too busy to do a full troubleshooting with it all.
  • GospelTruthGospelTruth Posts: 376
    Sounds obvious, but did you switch the speakers and move the right one to the left and the left to the right? If the one speaker is still lower when moved, then you've isolated it to the speaker. If it's still the right channel, then it's your pre or room. Best way to see if it's the speaker though.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
    edited June 2018
    So I tried switching the channels at the input, no help. I just switched the speakers a few minutes ago. In both cases it still leans to the right, so it’s not the speaker.
    If it’s not the speakers or the pre, it’s either the cables or room. Obviously I’m trying the cables next.
  • joecoulsonjoecoulson Posts: 3,441
    Room dynamics for me always changes the perceived output of each side. I have windows/Wall left and open right so it always sounds louder from the left side. I’m sure that’s obvious but...
    Auralic Vega G1/Rega TT/Denon SACD - PS Audio SGC - PS Audio M700x2 - Elac Adante AF-61
    I’m not positive, but I think I may just have some hearing loss in my left ear. Maybe one too many loud concerts or something. Guess I’m going in to get my hearing checked...
  • Airplay355Airplay355 Posts: 4,294
    Can you use a db meter app or db meter to test individual channels? Or, unplug a speaker and do it the old fashioned way :)
    edited July 2018
    Airplay355 wrote: »
    Maybe. I didn’t even think to check for an app. I’ll have to look into that.
    I have a free db meter app just called db meter. Seems to do the job well enough. It's not something I would use to setup room correction software but maybe it will help you figure out if one speaker is a few db lower than the other. It's an iOS app but maybe there's an android version as well.
Howdy, Stranger!
