Any real soundbars out there?
gwh
gwh Posts: 1,451
Yep Google is my friend but it does return a lot of crap to wade through.
Interested in a passive LCR soundbar that is big up to 60 inches in length depth and height not a real issue since it will be sitting on a large piece of furniture/gear cabinet. Are there any with 5 1/4 or 6 inch drivers?. I've looked at some sound bases but those tend to be short in length.
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
  • BlueFox
    BlueFox Posts: 15,251
    I bought this Samsung to go with my 65” Sony XBR900F, and I love it. It is pretty cool how attaching an HDMI cable between it and the TV automatically switches the TV sound to the sound bar, and turns it on with the TV.
    Not sure what passive means.
    https://www.amazon.com/gp/product/B06XGWGVQG/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
  • tratliff
    tratliff Posts: 1,662
    Check out the Yamaha’s. Not as big as you describe but I have been happy with mine. I have one in the living room and one in the bedroom.
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited June 2018
    BlueFox wrote: »
    Assuming he means a soundbar with no internal amplifier, so a receiver will be needed for power.
    Here are some options, although I don't think there will be many with larger drivers.
    https://goo.gl/MJsKvU
    EDIT: Link goes to Crutchfield. Original link did not play well with Vanilla.
  • TopperDude
    TopperDude Posts: 166
    Look into some of the DefTech Mythos bars as well as the GoldenEar SuperCinema range
  • erniejade
    erniejade Posts: 6,314
    For powered i was impressed with the polk maginifi max from what i heard at best buy. Not sure on non powered for sound bar only and not a complete HT rig.
  • gwh
    gwh Posts: 1,451
    Man that Goldenear SuperCinema 3D Array XL looks pretty sweet.
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • TopperDude
    gwh wrote: »
    its not cheap but if your looking for an awesome passive bar, its a pretty cool route to consider
