Any real soundbars out there?
Yep Google is my friend but it does return a lot of crap to wade through.
Interested in a passive LCR soundbar that is big up to 60 inches in length depth and height not a real issue since it will be sitting on a large piece of furniture/gear cabinet. Are there any with 5 1/4 or 6 inch drivers?. I've looked at some sound bases but those tend to be short in length.
Thanks,
G
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
I bought this Samsung to go with my 65” Sony XBR900F, and I love it. It is pretty cool how attaching an HDMI cable between it and the TV automatically switches the TV sound to the sound bar, and turns it on with the TV.
Not sure what passive means.
https://www.amazon.com/gp/product/B06XGWGVQG/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Three 20 amp circuits. -
Check out the Yamaha’s. Not as big as you describe but I have been happy with mine. I have one in the living room and one in the bedroom.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
Here are some options, although I don't think there will be many with larger drivers.
https://goo.gl/MJsKvU
EDIT: Link goes to Crutchfield. Original link did not play well with Vanilla. -
Look into some of the DefTech Mythos bars as well as the GoldenEar SuperCinema range
For powered i was impressed with the polk maginifi max from what i heard at best buy. Not sure on non powered for sound bar only and not a complete HT rig.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Man that Goldenear SuperCinema 3D Array XL looks pretty sweet.HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
its not cheap but if your looking for an awesome passive bar, its a pretty cool route to consider
