TSi 500 - too much bass
zioniaczioniac Posts: 8
So I recently bought these and have them hooked up to my 2 channel Onkyo TX-8050 receiver and I've noticed that there is too bass. And not good bass, sort of rumbling bass. I left the jumpers on the bi-wire speakers terminals and connected some monster cable to the lower terminal. Has anyone else run into this sound problem? I've played many different styles of music, and even the most quiet film score seems too bassy. I of course have adjusted the levels on the receiver and it doesn't sound as good as it should.
  • ClipdatClipdat Posts: 7,961
    What is your source?
  • zioniaczioniac Posts: 8
    Playing Blu-rays and CD's through a Oppo BDP-203 and vinyl with a Audio Technica LP-60. All components and even the speaker cable is the same as before, the only thing that has changed is the speakers. My old Philips speakers worked fine.
    I have no optimizers or equalization on. The bass is at 3/4 and the treble is all the way.
    What does this mean? Can you post a photo of the knob positions?
    zioniac wrote: »
  • tonybtonyb Posts: 32,431
    zioniac wrote: »
    Dontcha think that's a bit too high then ?
  • Jimbo18Jimbo18 Posts: 2,173
    Clipdat wrote: »
    zioniac wrote: »
    His receiver has knobs on the front for Bass and Treble. I assume that means he has the knob at 3/4's of the way around. That might have been okay with his old Phillips speakers, but it's probably causing his boom-i-ness now.
    HT - Pio Elite SC-63, Nuance Spatial 3S, Spatial Cen S, FXi50 surrounds, Def Tech PF 15TL+, Belkin PF30, Samsung UBD-M7500, Furez 12-2.
    Bedroom - Samsung UN50RU7200, Denon 2808ci, Monitor 5jr+ Series 2, Polk T30 center, Furez 10/2,
    LOL. Holy cow, if that's it.. I mean...
    Put the bass knob at the "12:00" position and carry on.
    Jimbo18 wrote: »
    Yeah, leave the bass and treble knobs at the center "12:00" detent. Problem solved.
    Not problem solved, but guys anyways.
  • pitdogg2pitdogg2 Posts: 16,314
    zioniac wrote: »
    please explain
    If you turn the levels down, it sounds pretty flat. Once the bass reaches a certain point it becomes rumbling. I have tried every setting. Would you suggest hooking the cable to the upper connectors on the speakers?
  • F1nutF1nut Posts: 44,493
    Listen to what people are telling you. Turn the damn tone controls to flat. I suspect you've been listening to pumped up frequencies for so long that you don't know what the music is actually supposed to sound like. Try this, set them to flat and listen to your rig that way for a week. By that time you should have adjusted to the sound and I'll bet you like it.
    edited June 2018
    An additional comment. After the week is over buy some better speaker/interconnect cables. What you are using now is not doing you any favors.
    It looks like he's got them "integrated" into the wall though, for a no cables look!
    I run absolutely no tone controls. I have them turned off on my pre so my dipstick friends can turn them all they want and it does nothing.
  • mrlorenmrloren Posts: 2,289
    I agree, turn them knobs down to flat or close to it. Also please check your connections making sure + to + and - to -, Sometimes having one crossed will cause funky sounding equipment.
    Not a big fan of monster cable either. Monoprice is better and cheaper. Do yourself a favor, call Doug and get some Furez https://douglasconnection.com/Furez-12-AWG-2-Conductor-Speaker-Cable-Raw-FZ122.htm Far much better cable than Monster. Before buying that Monster 16awg stuff you would be better served going to Best Buy and getting Audioquest X2.
    Family Room:
    Samsung UN75RU710DFXZA,
    Denon AVR-X4400H, Emotiva XPA3 GEN3
    Oppo BDP-93,Sony UBP-X800BM, WD Live HUB.
    Main: Polk LsiM 705
    Center: Polk LSiM 704C
    Front High/Rear High In-Ceiling Polk 80F/X RT
    Surrounds: Polk S15
    Sub: HSU VTF3-MK5
    Bed Room;
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S35
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES AVR, Sony DVP-NS3100ES for disc
    Cerwin Vega AT-12 (blasters) Advent Prodigy (listening)
    Old sony 12" Sub
    Mini tower PC with 400GB of music
    Could it also be that his receiver is malfunctioning somehow?
    What did the old "Philips" speakers sound/look like?
  • motorhead43026motorhead43026 Posts: 3,635
    edited June 2018
    The same Philips that makes light bulbs and electric toothbrushes?
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; S60'S, M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    There are three things that give a man a false sense of courage, a keyboard, alcohol and a firearm.
    Motorhead, 4.12.20
    tonyb said " but even socialists can do a good thing here and there
    Social media makes dumb people dumber and smart people dumb and dumber.
  • codycatalistcodycatalist Posts: 2,661
    I'll add myself to the list of people who used to use tone controls but now does not. Simply not needed, granted my speakers are a bit of a step above TSI500s but even with my TSI200s I didn't touch the tone controls.
  • verbverb Posts: 10,154
    @zioniac btw welcome to the forum! I too traveled a path similar to yours. I was equalizing the audio output in a similar manner. The old rock and roll "smile" on my equalizer, if you will.
    Start out flat. Enjoy some familiar tunes, study the nuances. Yes you can tweak the bass/treble, but ever so slightly to taste. As mentioned before, you may have been (like me) so used to artificially tweaking the output I never really had a chance to experience the music as intended.
    Certainly as you continue to upgrade, you will notice the improvements in the music!
    The same tunes will sound like new! That, fellow Polkie, is our journey.
    We're here with you! :smile:
    Basement: Polk SDA SRS,Cary SLP-05 Pre,Enlightened Audio Designs CD Transport,Northstar Designs Excelsio DAC,Cambridge 851N streamer,Marantz SA-14 SACD,McIntosh MC300 Amp,Silnote Morpheus Ref2 Digital Cable,Furman 15PFi Power Conditioner,Pangea Power Cables,Wireworld Oasis 8 RCA IC's,MIT Shotgun S3 IC's,MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC,EAR Acute CD Player,EAR 834L Pre,Northstar Designs Intenso DAC,PASS ACA Monoblocks,Denon UDR-F10 Cassette,Acoustic Technologies Classic FR Speakers,SVS SB12 Plus sub,MIT AVt2 speaker cables,IFI Purifier2,AQ Cinnamon USB cable,Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks,Tisbury Mini Passive Pre,Tjoeb 99 tube CD player (modified Marantz CD-38),Analysis Plus Oval 9's,Zu Jumpers,AudioEngine B1 Streamer,Klipsch RB-61 v2,SVS PB1000 sub,Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated,Cambridge CXN v2 Streamer,Rotel RCD-1072 CD player,Furman 15PFi Power Conditioner,Polk RT265 In Wall Speakers,Polk DSW Pro 660wi sub
    You betcha. Philips has made some of the best CD transports around, but they never made a decent speaker.
  • Viking64Viking64 Posts: 5,242
    Philips even had their own record label. I think they even founded Wisseloord Studios.
    I'd also pull them out a bit more from the wall. Maybe a throw rug too as that wood floor isn't helping matters either.
  • mdaudioguymdaudioguy Posts: 5,137
    zioniac wrote: »
    Not problem solved...
    Well, you can't really complain about too much bass, when you're the one who boosted it, right? :p
    Seriously, I also used to tweak the knobs, until I started to learn more about equipment and how to get better sound. It took some getting used to, but I always run flat now.
    Welcome to CP! Stick around, keep an open mind, and you might be surprised what you learn.
  • mlistens03mlistens03 Posts: 2,741
    mdaudioguy wrote: »
    I know I was!! :)
    signature is in the spoiler window :)
    Not Tom or Trey or Jim just Micah
    Martin Logan LX16s, NAD 1155 preamp and 4155 tuner courtesy of DaddyJT, NAD C352 playing power amp, BJC Belden cables, Technics SL3200, Marantz CD6004 CD player and Audio Technica cartridge courtesy of Drew/Clipdat, Salamander Archetype rack
    I've always thought the goal of high-end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
    I'm also wondering if you have the metal straps connecting the top and bottom posts on the back of the speaker connected.
    edited June 2018
    Just found this on craigslist. Vintage 1977 had some good reviews and cost $325.00 new! I gather it was an attempt by Philips to break into the high end stereo segment, although it was short lived.
    Not meaning to hijack the post, just fascinated by the Philips stuff.
    Motorhead, 4.12.20
  • rooftop59rooftop59 Posts: 6,426
    zioniac wrote: »
    Thanks a nice looking rig! Welcome to the forum. Some of these guys are a little rough around the edges, but there is lots of good advice to be had here.
    Music is like other refined sensory experiences. If you are used to drinking Franzia "chillable red" and then someone hands you a glass of really good, dry chewy cab chilled at 62 degrees, you might just spit it out. But if you drink that cab for a week or two, you will never go back to that box crap. Your senses adjust to what you are used to and your mental expectations adjust along with them.
    So yea, turn the tone to flat, pull the speakers out (that is contributing to the boomy bass), and give it at least 3-4 days, preferably a week. Then go back and forth between tone and no tone and see what you like. If you still like the tone controls, rock on, its your money and your system. But I imagine you will like the neutral sound of no artificial tone...
    Living Room 2.1: Dynaudio Contour 1.3mkii; Martin Logan Grotto sub; Cambridge Azur 851A; Cambridge Azur 851D; Bryston BPD-1
    Game Room HT: Denon AVR-X4200w; Definitive Technology SM350; Definitive Technology LCR2000; Definitive Technology Procinema 800; Mirage Nanasats; Sub - HSU VTF-2 MK5
    Master Bedroom
    Cambridge Azur 551r; Definitive Technology SM45; ACI Titan Subwoofer; Squeezebox Touch
Howdy, Stranger!
