Can you leave your ipad plugged in?
This Lightning server doesn't lock up as much if I leave it on. Can you just leave it plugged in without hurting it?
  • txcoastal1txcoastal1 Posts: 10,803
    afterburnt wrote: »
    Oh hellNO it will melt
  • afterburntafterburnt Posts: 6,163
    And burst into flames?
    iPad batteries last a long time
    I don't like keeping any of my portable topped off so to speak. You can probably use a couple days then plug in over night and so on
  • msgmsg Posts: 5,188
    edited May 2018
    Bruce, is it the app that locks up when your iPad's display goes to sleep? This is for your Auralic Mini, yes?
    iPads have pretty good battery life, don't they? Maybe you can set your display to stay on all the time, and just dim it as needed with the quick-access control during your listening sessions.
    But yes, what Ron said - it'll melt.
    And burst into flames.
    I've seen it a million times.
    While playing tunes set iPad to stay auto lock off
    Yes you can leave plugged in while doing so
    @msg Scott, correct. I do have the display turned down but I don't see the sleep settings.
  • rpf65rpf65 Posts: 2,105
    Sleep settings, maybe do not disturb.
    Your auto-lock function is under display and brightness.
  • BlueFoxBlueFox Posts: 12,555
    I keep both my iPads plugged in all the time. Same with my iPhone when at home.
    Bud - Silicon Valley
    Lumin X1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    rpf65 wrote: »
    Yes, this. I have an old iPhone I use for when I go riding, and if I want to sync Spotify for offline, I have to disable auto lock until it's synced, or else it stops syncing when the display sleeps. Sounds like what's happening to your Lightning app, Skip confirms.
  • mlistens03mlistens03 Posts: 2,665
    edited May 2018
    I keep my iPad mini plugged in to full charge, then I unplug it and use it down to around 30-40% or so (usually 2-3 days) and then go and set it on my desk and plug it in til it’s charged.
    I don’t think it’s good for a battery to be charged to a high capacity for extended periods of time, or to be fully dead for extended periods of time. It’s recommended by Apple, Lenovo, drone manufacturers, anyone who makes batteries, etc. to store your device fully shut down at around 60% battery. If you are coming back in a few days, then don’t worry about it, but if it’s more than a week, I discharge it down to around 60% and shut it down.
    Not Tom or Trey or Jim just Micah
    KEF Q150s, NAD 1155 preamp and 4155 tuner courtesy of DaddyJT, NAD C352 playing power amp, BJC Belden cables, Technics SL3200, Marantz CD6004 courtesy of Clipdat, Salamander Archetype rack, Millenium Falcon :)
    I've always thought the goal of high-end audio was not to have your neighbors bang on the wall and say, 'Turn that darn music down' but to have your neighbors bang on the wall and say, 'Tell your friends to go home and you can practice later this week'.
    Resident Child of Club Polk
  • steveinazsteveinaz Posts: 19,123
    I wouldn't, Ipad power supplies get really HOT.
    Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amplifier: Parasound Halo A21 - Speakers: PSB Imagine T2
    Mine don't. I have a regular iPad Retina, and an iPad mini-Retina, and neither get hot even though they are plugged in 24/7.
    Lumin X1
    Sony XA-5400ES SACD
  • rooftop59rooftop59 Posts: 6,209
    BlueFox wrote: »
    The charging block plugged into the wall doesn't get hot? I think that's what he means. My iPad doesn't get hot but the charging block could fry an egg...
    Living Room 2.1: Dynaudio Contour 1.3mkii; Energy s10.2 sub; Cambridge Azur 851A; Cambridge Azur 851C; Bryston BPD-1
    Game Room HT: Denon AVR-X4200w; Definitive Technology SM350; Definitive Technology LCR2000; Definitive Technology Procinema 800; Mirage Nanasats; Sub - HSU VTF-2 MK5
    Master Bedroom
    Cambridge Azur 551r; Definitive Technology SM45; ACI Titan Subwoofer; Squeezebox Touch
    rooftop59 wrote: »
    BlueFox wrote: »
    Some of our charging blocks get warm, and others don’t. None of them get hot enough to be worried about, IMO.
    rooftop59 wrote: »
    BlueFox wrote: »
    No. Just checked. They are room temperature.
    Lumin X1
    Sony XA-5400ES SACD
    I'm talking about the charger. What's odd is my wifes Ipad mini 3 PS gets hotter than my Ipad mini 4, but even my 4 PS gets pretty darn warm.
Howdy, Stranger!
