Can you leave your ipad plugged in?
This Lightning server doesn't lock up as much if I leave it on. Can you just leave it plugged in without hurting it?
    txcoastal1 Posts: 13,519
    afterburnt wrote: »
    Oh hellNO it will melt
  • afterburnt
    afterburnt Posts: 7,892
    And burst into flames?
    iPad batteries last a long time
    I don't like keeping any of my portable topped off so to speak. You can probably use a couple days then plug in over night and so on
    msg Posts: 10,473
    edited May 2018
    Bruce, is it the app that locks up when your iPad's display goes to sleep? This is for your Auralic Mini, yes?
    iPads have pretty good battery life, don't they? Maybe you can set your display to stay on all the time, and just dim it as needed with the quick-access control during your listening sessions.
    But yes, what Ron said - it'll melt.
    And burst into flames.
    I've seen it a million times.
    While playing tunes set iPad to stay auto lock off
    Yes you can leave plugged in while doing so
  • afterburnt
    @msg Scott, correct. I do have the display turned down but I don't see the sleep settings.
  • rpf65
    rpf65 Posts: 2,127
    Sleep settings, maybe do not disturb.
    Your auto-lock function is under display and brightness.
  • BlueFox
    BlueFox Posts: 15,250
    I keep both my iPads plugged in all the time. Same with my iPhone when at home.
    msg Posts: 10,473
    rpf65 wrote: »
    Yes, this. I have an old iPhone I use for when I go riding, and if I want to sync Spotify for offline, I have to disable auto lock until it's synced, or else it stops syncing when the display sleeps. Sounds like what's happening to your Lightning app, Skip confirms.
  • mlistens03
    mlistens03 Posts: 2,767
    edited May 2018
    I keep my iPad mini plugged in to full charge, then I unplug it and use it down to around 30-40% or so (usually 2-3 days) and then go and set it on my desk and plug it in til it’s charged.
    I don’t think it’s good for a battery to be charged to a high capacity for extended periods of time, or to be fully dead for extended periods of time. It’s recommended by Apple, Lenovo, drone manufacturers, anyone who makes batteries, etc. to store your device fully shut down at around 60% battery. If you are coming back in a few days, then don’t worry about it, but if it’s more than a week, I discharge it down to around 60% and shut it down.
  • steveinaz
    steveinaz Posts: 19,546
    I wouldn't, Ipad power supplies get really HOT.
  • BlueFox
    Mine don't. I have a regular iPad Retina, and an iPad mini-Retina, and neither get hot even though they are plugged in 24/7.
  • rooftop59
    rooftop59 Posts: 8,120
    BlueFox wrote: »
    The charging block plugged into the wall doesn't get hot? I think that's what he means. My iPad doesn't get hot but the charging block could fry an egg...
    Game Room 5.1.4:
    Bedroom 2.1
  • mlistens03
    rooftop59 wrote: »
    BlueFox wrote: »
    Some of our charging blocks get warm, and others don’t. None of them get hot enough to be worried about, IMO.
  • BlueFox
    rooftop59 wrote: »
    BlueFox wrote: »
    No. Just checked. They are room temperature.
  • steveinaz
    I'm talking about the charger. What's odd is my wifes Ipad mini 3 PS gets hotter than my Ipad mini 4, but even my 4 PS gets pretty darn warm.
