Sub hookup for 7600 system?
jchas41
Hi, I am going to be hooking up my system soon and am wondering if I should use the LFE out instead of the speaker wiring Polk method. I have a Pioneer Elite 54TX AVR and a Polk PSW505 sub. Thanks.
My Set-Up:
Sharp LC60E88UN- Display
Yamaha RX-A2020- A/V Receiver
Pioneer Elite BDP-23FD Bluray Player
Toshiba HD-A2 HD-DVD Player
Velodyne DPS-12 - Sub
Polk RTi8's- Fronts
Polk CSi5 - Center Channel
Polk FXi A4's- rear surrounds
Monster HTS2600 Line Conditioner
PS4
Polk RTi8's- Fronts
PS4
Post edited by jchas41 on
I would say LFE, but hey, that's just me.
Great, I want to use the LFE, makes it much easier. Plus, I spent good money on a subwoofer connect, I'd like to use it.;)My Set-Up:
Polk RTi8's- Fronts
PS4 -
See I would say the opposite go the polk method this would provide you with a better xover setup and tuning
His receiver should have adjustable crossover points. Also if you use the LFE then you can turn down the subwoofer by adjusting the LFE level on the receiver using the remote, instead of having to get up and adjust the sub.
good point as long as his receiver can adjust the xover.if not the polk way would be best
I can adjust the crossover settings on the reciever and the Elite has like 5 settings. What do you think I should set it at, based on my system?My Set-Up:
Polk RTi8's- Fronts
PS4 -
I would say 100 or 120.....depends on the frequency range of the sats
edit I think it's the other way...80 or 90 -
I will set it at the THX level of 80 then. Thanks.My Set-Up:
Polk RTi8's- Fronts
PS4
