Should I connect my TV to my DAC?
afterburnt
I watch a lot of music documentaries and I am wondering should I run an optical cable so I can listen through my Ushers or is this against the law?
Do you own an optical cable?
You can...wouldn't hurt.HT SYSTEM-
lsi 9's -
You could try plugging it in.
But wait a few more days. Best not to rush into things.afterburnt wrote: »Yeah, it's sitting by the TV looking at me.
Obviously the quality of the digital circuitry in the tv is the limiting factor here, but it will still sound better absolutely. what is the source? A built in app on your tv? If that’s the case then a Roku or some other dedicated streaming device would be a better so Bri g optIon, and yuh can get one for like 50 bones if u look around...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Be careful. Sometimes sending light through one of them there op-tickle cables opens a wormhole to another dimension. You don't want to slip into the abyss of a hell where Bon Jovi is the frontman for Led Zeppelin.
@rooftop59 its the Amazon app on the TV. I have a Fire Stick that I never use, why is that better?
I watched Jon Bon Jovi on the Rock & Roll Hall of Fame this weekend and I'm 99% sure he completely plucks all of his eyebrows off and then draws them on. I did enjoy his speech though. Just thought I'd share that random tidbit.
Yeah, he has really let himself go.
I found his lack of eyebrows completely distracting.
afterburnt wrote: »@rooftop59 its the Amazon app on the TV. I have a Fire Stick that I never use, why is that better?
Well, that won’t be better because it’s only hdmi and you need optical coax or usb I’m assuming. You would need dedicated streaming box with optical out like the Roku ultra or an older amazon fire tv. Those are optimized for streaming, they might give you a slightly better audio signal, but probably not by much honestly.
Hook it up to the tv and let er rip!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
@rooftop59 ok I got ya, I wasn't thinking boxes all I got is sticks. My Roku stick is out of town now.
I was concerned about insulting my Ushers. -
Kinda like that guilty feeling you get when you play a porno video through a $1k DAC?afterburnt wrote: »I was concerned about insulting my Ushers.
Do you get smellavision? -
Hmmm, this cable is screaming with no signal going to it, what does it all mean Basil?
That’s what I doMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Does it help?
anyone ever had their optical cable scream and cry for no apparent reason?
Explain2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Plug it into the TV saw light at the other end. Plugged it into the DAC and it makes a God awful growl before switching the TV output to optical.
Growl coming from the speakers when you do this??2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Correct, from the Ushers
But normal once it's switched??2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
No It just howls all the time
Have you tried another optical source2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
That your little world won't let you go?afterburnt wrote: »anyone ever had their optical cable scream and cry?
txcoastal1 wrote: »Have you tried another optical source
Duh, I could put it on the HT to test it. I was just stuck on "the other optical cable I have it too short" thanks Ron. I can't think my way out of a paper bag! I almost died like that a couple of times.
Looks like it's the new TV!
Got HDMI?Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
How did you ever hook up all this great gear? Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boomboxSome final words,
Warren
