Basement Leak at Verb's House!
Me too.If I ever went to Verb's house, I would probably take a leak in his basement. Just sayin'.
Only I'd go on that same wall after it's fixed.
And on any spare Monoprice Tube Integrateds.I disabled signatures. -
Well there is a bathroom down there, in case you're not used to indoor plumbing!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
It's just not as fun. Kinda like when you're camping, you know?I disabled signatures.
Exactly! Or at the edge of the property 200ft away! Gotta drain the vein!
Or like when you're in the towel section of Bed, Bath & Beyond and Led Zeppelin's "The Lemon Song" is playing over the PA and you made eye contact with that hot cashier on your way in and.....nevermind.
Remember to never buy towels at BBB!
You might want to think twice about that case of Mountain Dew I sent you while you are at it.
I guess there was some objectionable language in the video I posted... Oops! But leaking on one of those amps might have the same effect as leaking on an electric fence.
My wife is first generation as well. Juist ja!2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s -
how did you know I was of Dutch heritage? 1st generation American! Those Dutchies sure know all about water management!
Oh. Crap. You too?Gustard X26 Pro DAC
You guys are about to get passed.
On tha left haaand side, of course.I disabled signatures. -
Wow! One of the most obscure references I've heard in a while! Gold star, Scott! -
Day 2 and all is good. Dutchies prevail!
Golden Earring were Dutch, weren't they?
In a past life I was a QC manager for dry cast and wet cast concrete product company and can say with certainty you are going to have to do some more work to remedy the issue.
As mentioned hydraulic cement should be used such as damtite. Keep in mind all concrete is porous and that kind of water is going to find it’s way in other areas.
That hole may be the most visible but I’m betting there are other cracks in the poured wall that are seeping at least. Also know that the water had already made it past the tar coating on the outside of the wall.
There were similar issues with our home but were remedied prior to our purchase. The remedy included two yard drains to remove surface water around the house, which are marvelous btw. Also the perimeter of the home was dug and French drains were installed. While the ground was dug out a second drain from was installed under the foundation and plumbed to a second sump well with an two additional pumps, one on a battery backup.
Been here two years and witnessed record breaking rainfall with local flooding, but our basement has stayed dry. We have bare 9ft poured walls in our basement so it’s easy to inspect, but I will say it’s incredible how much water pours in our sump wells during a periods of heavy rain. The pumps kick on every 30 seconds or so at those times to empty the wells.
With your wall leaking like that you’re getting some serious water as we are and you should strongly consider those types of remedies. Good luck.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant -
Yep agreed. The obvious source was the rebar hole. Another thing to worry about!
mhardy6647 wrote: »Golden Earring were Dutch, weren't they?
Ja, dat zijn ze!
https://youtu.be/Sm1q1XoN_Qo Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yes. Shocking Blue also. Their hit "Venus" sort of opened the doors for several Dutch bands of that era. Focus, Solution, Mouth and MacNeal, The George Baker Selection, Tee Set, and of course Golden Earring. -
Home Theater/2 Channel:
dhsspeakerservice.com/ -
Heck, I remember nearly all of them
As a nearly pointless aside, back in the halcyon days of world-wide short wave
broadcasts, I was a big fan of Radio Nederland. Had a bumper sticker from 'em on my Bronco 'n' everthing.
Ironically, despite many trips to Europe in the ensuing decades, I have yet to visit
the Netherlands. Would like to go sometime. Heck, one of my clients is even a Dutch biotech company -- but we've done our business by telecon.
jeremymarcinko wrote: »In a past life I was a QC manager for dry cast and wet cast concrete product company and can say with certainty you are going to have to do some more work to remedy the issue.
Having done many myself, this is good advice. Those plugs are nice you used, but they are a temporary solution. As long as water is still entering the hole from the outside, that hole will eventually become bigger, and the plug worthless.
Getting the water away from the foundation is key, then fixing the known holes on the outside with hydraulic cement, letting it dry, and covering that with either tar or a rubber compound such as what they fix cement swimming pools with and you'll never have a leak again.
If you do drain tile, make sure you have enough wash stone around the pipe to keep it from eventually clogging. If you do a French drain type of trench, make sure you put a fabric paper over the top to keep dirt and stone separated, and not get clogged up also. Good luck to you.HT SYSTEM-
lsi 9's -
Last night we had horrendous rain. Water table up way high, as before. Verb's basement is dry! Yay!
How much do you think it's going to cost to fully "fix" the issue from the outside? $5k?
I just have to re-grade the areas of concern. That should take care of it. Idea is to get the water to flow away from the house.
I have some gutter work to do as well.
All DIY stuff
Yeah it's amazing how cleaning out a gutter will stop a basement water leak
That's wonderful news, Dave! Now to get the poltergeist out of your attic.
I ain't going up there dude!
Update - Last 24 hours we've had significant rainfall. As before, water table way up high, the river at the back of the property water level up to the top of the bank. First thing this morning I checked the repair, bone dry!
https://www.youtube.com/watch?v=c7ZIoWEbRX8
https://youtu.be/MF1Rsu8IYxg
https://www.youtube.com/watch?v=ubYyofUBnec
