Official SVS owners thread!
11415171920
  • gfong
    gfong Posts: 1,079
    polrbehr wrote: »
    gfong wrote: »
    Upgraded the feet on my SVS PB12 NSD to the SVS Soundpath feet. Isolated the sub very well and tightened the bass up. Home theatre use only.
    I saw those on their website the other day, was wondering if they would fit my
    PB12-NSD/2 though, is yours down-firing with the base plate as well?
    Mine is front firing. I would guess if you have feet on it now that screw in that the Soundpath ones would work. There are 3 different size screw sets that come with them. The instructions said that all SVS cabinet style subs use the 1/4-20 thread size.
    Here is the SVS Customer service phone number from the instruction book 877-626-5623. 9to9 est Monday to Friday. Maybe they could tell you if the feet would fit that plate that is on your sub. Good luck.
  • gfong
    gfong Posts: 1,079
    polrbehr wrote: »
    gfong wrote: »
  • DaveHo
    DaveHo Posts: 3,580
    polrbehr wrote: »
    gfong wrote: »
    I have one of the /2 subs as well. The screws go through the base plate & standoffs into threaded inserts in the cabinet. With long enough screws, I think the Soundpath feet will work just fine. Though you'd likely need the 6 pack they sell instead of the 4.
  • polrbehr
    polrbehr Posts: 2,842
    Thanks, I wondered since I see they sell them in 6-packs.
    Thanks @gfong for the info too.
  • KYFHO
    KYFHO Posts: 76
    I’ve had my SB16 Ultra for a week now. I gotta say, this thing is amazing! I replaced dual 12” Klipsch subs and couldn’t be happier. I was thinking about going dual but it is absolutely not necessary as this sub fills my room with a ton of headroom to spare (my dedicated room is right at 1200 cf).
    The output of the SB16 is phenomenal and just blows away the Klipsch subs. I added the soundpath isolator feet and that really helped with the rattling of my walls. The first movie I played with this sub was Tron. I never realized the low bass I was missing. With music it’s even better. Expensive but worth it in my opinion.
  • danzilla31
    danzilla31 Posts: 94
    Man I'm late to this party I'm running 2 PB 2000's in my main system. Was running them with 3 Polk S 60's but you guys got me so spoiled with the 2000's I had to move em to another room and sold the extra one for 3 SVS prime towers for the main room. Those S60's sound GREAT even for straight up stereo listening in my other room. But I ain't gonna lie those Primes are something special. Those PB 2000's ROCK and with the feet ROCK even more. But it's a huge open area and I hafta run em a little hotter then I like the amp doesn't even get warm tho Lol. But I know to get the sound I want I'll need to upgrade First I'm going dual PC 2000's behind the couches for quads then use the trade up to figure out what I want to do for the upgrades on all 4 Lol. s9e29xvcnimj.jpg
  • danzilla31
    The Piano Black is beautiful tho.... they do a flawless job... but if it doesn't go with your gear..... oh well you'll just be forced to live with it.... Congrats and enjoy!
    I was concerned about reflections, but after studying things a bit I believe that won’t be an issue. I suppose if it came down to it I could spray a matte black finish on it, but I'm not looking for extra work.
    Hey congratulations on your SB 4000 Svs thinks I'll need dual PB 4000's for my wide open area but I think I'll stick 2 of they're cylinders behind the couches for a near field effect with the fronts well see if I need more. Hope your enjoying your sub always appreciate your insights looking 4ward to your impressions!
    F1nut Posts: 51,673
    It's a beast when it needs to be for movies and very musical for the occasional music video.
  • mrloren
    mrloren Posts: 2,471
    Nothing like a good sub, Bummer you'r on the other side of the country. I would have helped you move that beast. I had no problems with my 85lb VTF 3.
    F1nut Posts: 51,673
    Moving it was easy enough once I put my thinking cap on. After dead lifting the first, well technically the second one, I quickly figured out how to pack and unpack them without any lifting involved.
  • danzilla31
    That was what surprised me the most they're ability to do both movies and music so well. I can't wait to upgrade and experience more of the level of quality your enjoying right now.
  • danzilla31
  • joecoulson
    joecoulson Posts: 4,943
    Proud new owner of an SB16 Ultra
  • Mikey081057
    Mikey081057 Posts: 7,127
    Congrats... They should just change the name of that sub to BMF
    Garage | Polk Monitor 5B's
    F1nut Posts: 51,673
    You should spike that sub, it'll tighten up the bass.
  • joecoulson
    I will. I just have no feet on it while I verify that’s the best placement. I just got it. It’s so frigging heavy.
  • joecoulson
    edited July 2018
  • joecoulson
    Done
  • joecoulson
    Question, if any of you have one of these, if you get really close to the driver w your ear, can you hear what can only be described as “ white noise “? Very faint, still present with no rca connection. Again, you gotta be up on it.
    F1nut Posts: 51,673
    edited July 2018
    I've got it's baby Huey bother, dead silent, but the sub cable is connected and I'm not pulling it off.
    Is the volume set per your pic at -10dB when you hear the noise?
  • mlistens03
    mlistens03 Posts: 2,767
    joecoulson wrote: »
    I’ve never owned any SVS subs, but my old Velodyne CHT-10 and VX-10B made this noise, along with my friends BIC America F12 and his old Polk PSW-10.
  • joecoulson
    Almost sounds like a mini fan inside the box. Again it’s quiet, but I wouldn’t think this level of sub would have that noise present. I have emailed SVS to see what they say.
  • joecoulson
    KYFHO wrote: »
    Since you have the same sub, can you hear anything like the above description?
  • joecoulson
    This was response from SVS
    This is the noise floor of the amplifier (essentially the signal-to-noise ratio) and is perfectly normal. As you noted, it’s not audible at the listening position or when source content is playing. When the amp drops into Standby, it should be completely silent. To ensure this, under System Settings, set the Subwoofer Standby to Auto. After 20 min of no signal, the amp will drop into Standby. Thanks.
    F1nut Posts: 51,673
    I was wrong, missed the part where you had to have your ear basically next to the driver. Yes, mine has the faint white noise sound.
  • joecoulson
    Ok cool. That makes me feel better about dropping 2k
    Thank you.
  • joecoulson
    All I gotta say is :D:D
  • KPGM
    KPGM Posts: 8
    In the market for a new sub and I keep hearing amazing things about SVS. In my budget range is the SB and PB 2000. Would you suggest one over the other if it's being used strictly for HT use. Would be pairing this with RTi A9's.
    thanks!
    Panasonic 60" plasma, Denon AVR-3313CI, Outlaw 5000, Polk Rti A9's, CSi A6, FXi A4's & A6's
  • mrloren
    HT = ported all the way.
    SVS are nice subs, HSU are good too but no free shipping.
