What FM antenna/s has/have worked for you?
Tony M
I've had success with these Terks. I've also liked and still use the ol rabbit ears and plastic tee ones.
https://www.ebay.com/itm/TERK-POWERED-AM-FM-AMPLIFIED-SIGNAL-ANTENNA-PI-B-INDOOR-HDTV-HOME-OFFICE-TV-USED/183186938649?epid=1600044590&hash=item2aa6cadb19:g:oTkAAOSwtfhYtKCh
And this one is awesome; The white fuzz is not on the original picture! That corrugated back plate folds down and there are two dials on the right side to help with dialing in the stongest signal.
http://www.terk.com/radio-antennas/?sku=AF1
outdoor is best hands down. winegard if still made..
Yes an FM Yagi with plenty of altitude and a rotator -- but good ones are harder & harder to find. I bought a little FM directional from MCM some while back (before they got sucked up by Newark) -- haven't put it up yet, though.
Meanwhile, I am using this little guy to listen to the one station we usually listen to.
DSC_9169 by Mark Hardy, on Flickr -
What do you do to prevent lightning strikes from entering what's hooked up to them?Most people just listen to music and watch movies. I EXPERIENCE them.
My subdivision doesn't allow external aerial type antennas. Yeah I know. Association Boards. Agree with Dogg, Winegard 6065 is highly touted. I too am am in search of a killer indoor antenna.
Winegard 6065:
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
mhardy6647 wrote: »outdoor is best hands down. winegard if still made..
On eBay right now:
https://www.ebay.com/itm/TECHNICS-16-5-FM-WING-ANTENNA-SH-F101-VINTAGE-MADE-IN-JAPAN/292404065121?epid=559615231&hash=item4414a3f361:g:pbIAAOSwKwVaVxhA
I get every station in the galaxy
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Outdoors and up high hasn't failed me yet. I even had good luck doing this in the past with a simple dipole spread out on a stick and placed up high.
On eBay right now:
Mine was $7.
I wouldn't recommend one for $135
I figured as much!
I've got a couple of terks that work quite well. This one from Audio Advisor looks like a good one for the price. I need one for a receiver in the garage and this might be worth a try.
http://www.audioadvisor.com/mobile/prodinfo.asp?number=GDFM1AHome Theater
Lightning arresters at the grounding block.
You could also drive a 12' ground rod in the ground with 6ga solid copper.
My antenna tower is 35' tall with a deep fringe channel master OTA antenna good to 80 miles for FM and much further on great days.
Not once in 30 yrs have i had a strike but there are was to minimize problems. -
Winegard 6065:
Is it still available? I looked on Winegard's site and only see a 'turnstile' type omni.
There do seem to be a couple of serious FM Yagis (or log periodics) on Google -- but I know nothing about most of the ones I saw, like this one (that I found looking for the Winegard):
http://dennysantennaservice.com/long-range-fm-antenna.html -
Winegards are no longer made but others are out there.
I used to use an antennae but can find any station I want on the internet.My New Year's resolution is 3840 × 2160
Great job at missing the entire reason for this thread and making a pointless post.Mikey081057 wrote: »I used to use an antennae but can find any station I want on the internet.
mhardy6647 wrote: »My subdivision doesn't allow external aerial type antennas. Yeah I know. Association Boards. Agree with Dogg, Winegard 6065 is highly touted. I too am am in search of a killer indoor antenna.
Winegard 6065:
Naw, discontinued. There was a NOS on eBay that recently sold. I did see the Denny antenna too, looks like a close facsimile.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
This one seems promising. Winegard HD-6010. Small enough to be attic mounted. Less than 50 bucks.
One could always make their own... Not difficult and you can tailor the length to pull in the frequency you want more effectively than the mass built units. Most single pole or loop antennas are built to sit dead in the center of the FCC allocated bandwidth... Not so good if the station you want is on either side of that spectrum.
Mikey081057 wrote: »I get every station in the galaxy
Uhhhhh...you just might be getting a strongly worded letter from the homeowners association for that one...LOL!.. -
Got one of these on my attic. Works good.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
A quick read of the Denny's page suggests it is a repurposed TV Yagi -- the FM band, as youse guyses likely know, lies between the old analog TV channels 6 and 7 in the VHF spectrum.
It's no more, and no less, than two center-fed dipoles at right angles to form a more-or-less omnidirectional antenna. No gain.
Not a bad antenna, but a far cry from a good, high gain, directional antenna.
Not in New Hampsha.
Live Free or Die.
Yeah, a tuned dipole ain't a bad antenna at all
I keep a mess of 300 ohm twinlead "in stock" for such projects. In fact, if anyone wants to build one and wants a hank o' twinlead, send me a note. I can certainly spare some.
https://www.electronics-notes.com/articles/antennas-propagation/dipole-antenna/fm-dipole-antenna.php
http://hf-antenna.com/003/
http://www.cyberpoet.net/writes/web/infwiz/spant.html
to calculate wavelength when you know the frequency, all's you need to know is the speed of light in a vacuum
which is 300 million meters/second (slightly faster than a Dodge Demon)
so, in our case, e.g., a station at 89.5 MHz (WVPR-FM in Windsor, VT) has a wavelength of
(300 x 10^6 meters/sec) / (89.5 x 10^6/sec) = 3.352 meters
and "lambda/4" (1/4 wavelength) = 0.838 meters = (about) 33 inches.
Note that one of those references above is for a 5/8 wave dipole (as opposed to a half-wave dipole).
This guy is asking way too much for his 6065:
https://www.ebay.com/itm/NEW-Vintage-Winegard-Chromstar-CH-6065-FM-Antenna/222907083538?hash=item33e64c2b12:g:EWoAAOSwMGhakfQrBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
mhardy6647 wrote: »A quick read of the Denny's page suggests it is a repurposed TV Yagi -- the FM band, as youse guyses likely know, lies between the old analog TV channels 6 and 7 in the VHF spectrum.
Yep. Aren't they directional though? Next thing buy a rotor, down the rabbit hole, you know the drill.
A good one is hyperdirectional -- and that's a good thing
I keep a couple of rotators & motors in stock, as a matter of fact.
Why did ConstantiDIPOLE get the works? That's nobody's business but the TERKS.
Not bad.
