Good cheap USB cable
Oh and how long is the longest you are supposed to go with USB?
    mhardy6647 Posts: 33,090
    afterburnt wrote: »
    Until it becomes obsolete and gets replaced by something else.
    *rimshot*
    :p
    txcoastal1 Posts: 13,134
    you're good with a 5M decent quality cable
    msg Posts: 9,495
    txcoastal1 wrote: »
    BZZZT!!! I thought 16ft was the limit?!? :D
    What're you using it for, Bruce?
    I just grabbed a couple of AudioQuest Forests to use in USB DACs. I like 'em. They got silbur.
  • afterburnt
    afterburnt Posts: 7,892
    @txcoastal1 Ron are you sure, that's a lot of cable.
    @msg Scott it's for my laptop to an ifi nano and to try my hand at digitizing some vinyl.
    msg Posts: 9,495
    Nice, Bruce.
    5m/16.4ft is the "limit" on USB, iirc, without some kind of boosting/conversion, but I think that's more for non-audio USB. My understanding is that the shorter the better. With a reasonably decent quality shield USB cable, I'd go up to 5m/16 to try. Mine are 0.75m and 2m. I use the shorter one for a headphone amp/dac, and the 2m stays in the home office setup.
    gudnoyez Posts: 8,078
    Just got a Wireworld Starlight 7 it easily trumps all my other USB cables don't go to cheap on one, unless you need a longer one than 2 meters.
    afterburnt wrote: »
  • afterburnt
    @gudnoyez Steve this is not going to get a ton of use but I need at least 3 meters. I kinda thought I heard you weren't supposed to go more than 2 meters.
    All seriousness, I used a 5M AQ Forest at most of my shows from laptop to DAC when I was running JRiver
    I'm using a Forest with laptop to OPPO not bad at all and a good price. I heard up to 2 meters is best.
    txcoastal1 wrote: »
  • afterburnt
    edited April 2018
    Ron that Forest is too much. Any thoughts on the AQ Pearl? Even that's too much, I only got eight bucks of change out of my ashtray.
    This Lucky Goldstar tablet's spell check bites!
    afterburnt wrote: »
    Ron that Forest is too much. Any thoughts on the AC Pearl? Even that's too much, I only got eight bucks of change out of my ashtray.
    Then move your chair or buy an Iphone/Ipad show your love to Apple u scrooge :D:D:D
  • afterburnt
    Apple is not only not right; it is not even wrong! LG is just stoopid.
  • afterburnt
    I am gonna get the bottom of the line Wireworld cable
    Clipdat Posts: 12,622
    Monoprice it is!
    https://www.monoprice.com/product?p_id=5438
    afterburnt wrote: »
    tonyb Posts: 32,908
    edited April 2018
    afterburnt wrote: »
    Check the other ashtrays. :)
    Look for a used one on US Audiomart. Your coin will go a lot further buying used. Though for the length you need and the budget you have, Monoprice is about your best option.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,722
    I have the Pangea cable and it works great, nice and cheap too
  • afterburnt
    @AsSiMiLaTeD i have a Pangea silver that I like but it's too short it was cheap though.
    @tonyb Amazon has a WIREWORLD for 42 bucks and I have a store credit so I can afford it.
    billbillw Posts: 6,216
    edited April 2018
    Find a Belkin Gold on eBay. Great quality, cheap. I'd stick with 3M or shorter.
    Here is one (no affiliation)
    https://www.ebay.com/itm/NEW-Belkin-USB-Hi-Speed-Cable-A-B-10ft-3m-Gold-Series-24K-Gold-Plated-Connectors/222873620288?hash=item33e44d8f40:g:-bcAAOSw-WFaoXco
    For rig details, see my profile. Nothing here anymore...
  • marvda1
    marvda1 Posts: 4,880
    billbillw wrote: »
    billbillw wrote: »
    I made an offer of $7 and it was accepted. you can get the 6 ft cheaper.
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • afterburnt
    @marvda1 same here. Thanks folks!
  • afterburnt
    @marvda1 how will you use it?
  • marvda1
    laptop to dac
    Puritan PSM156
