SDA2b's
13
  • dkfreebird
    dkfreebird Posts: 1,186
    It is 4 screws to pop a driver out and look at the back of it. It takes just a couple of minutes.Don’t need to worry about the crossover but while the driver is out you should be able to see the Crossover
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
    audioluvr Posts: 5,989
    gmcman wrote: »
    audioluvr wrote: »
    ThomasD wrote: »
    Those are the 2A's. If the drivers are good, new tweets and crossover will make them sound great!
    How can you tell if they are 2A's or 2B's by the front? I honestly don't know....reason I ask is my 2B's look exactly like those. On the back, there is a "B" sticker in the top right of the large label.
    Ancient Chinese Secret...
  • ThomasD
    ThomasD Posts: 260
    audioluvr wrote: »
    gmcman wrote: »
    audioluvr wrote: »
    ThomasD wrote: »
    No kidding. Seems to be some kind of secret. The 2B's have different drivers and are easier to TL. The 2A's have identical drivers but are more expensive to TL. I'm assuming the XO's are where all the magic is different then.
    Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
  • dkfreebird
    Yes,the 2a's have dual crossover boards where the 2b's have a single board.
    Oppo 103
    Pangea PC
  • ThomasD
    ThomasD Posts: 260
    So in the 2 years difference between the 2A's (3rd gen.) & 2B's (4th gen.) did they figure out how to fit 2- 4lb boards of electronics onto 1- 8lb board??? ;)
  • dkfreebird
    Not sure where you are getting the boards in weight. The 2b’s have one crossover.
    Where the 2a’s have 2 crossovers.
    Oppo 103
    Pangea PC
    F1nut Posts: 52,008
    It should be pointed out that Polk never designed or approved modification of the 2A in order to use the SL3000/RD0198.
  • ThomasD
    ThomasD Posts: 260
    Sorry, I was exaggerating the weights. Just making note of the fact that the quantity of drivers didn't change but the configuration/layout of the XO's seems to have been reduced. Was that because of an advancement in board design? I personally haven't seen either set of boards so I am curious.
  • ThomasD
    ThomasD Posts: 260
    Does that hold true for all Polk speakers that didn't originally have the SL3000?
  • Nightfall
    Nightfall Posts: 10,083
    edited April 2018
    ThomasD wrote: »
    Aside from 2B's and single SL2000 tweeter CRS I believe yes.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • ThomasD
    ThomasD Posts: 260
    Hmm.. Did not know that. Were the 2B's ever produced with SL3000's or was that simply a Polk approved upgrade? Don't want to sound ignorant but then is TL'ing a set of 2'A's or Monitor 7/10's a negative or bad thing?
  • Nightfall
    ThomasD wrote: »
    I believe that Monitor 7's and 10's both have a SL2500 variant so that's out of the equation.
    afterburnt wrote: »
    F1nut Posts: 52,008
    ThomasD wrote: »
    No, but Polk had a plan via a published schematic to release the CRS+ with the SL3000 tweeter and call it the 4.1TL. It just so happens that the CRS+ crossover and mid-drivers are exactly the same as the 2B. There was also a plan via a published schematic to release the Monitor 10 with the SL3000, but I'm not aware of such a plan for the Monitor 7.
    Toolfan66 Posts: 18,189
    edited April 2018
    It should also be noted that taking a 2A and making it a 2B/4.1TL is not that hard,and can be done, same goes for the CRS (single tweeter) to a CRS+/4.1TL..
  • muncybob
    muncybob Posts: 3,267
    What does "TL" stand for?
    Yep, my name really is Bob.
    Viking64 Posts: 7,628
    Tri-laminate
    Does it apply to tweeters, mid-woofers, or both?
  • FestYboy
    FestYboy Posts: 3,861
    FestYboy wrote: »
    Tweets only
    What's odd is that I keep seeing this phrase pop up, even in Polk literature and in Ray Smith's "SDA Handbook".
    6.5” Diameter tri-laminate polymer bass-midrange MW6500
  • ThomasD
    ThomasD Posts: 260
    Toolfan66 wrote: »
    Then for the 2A that would mean swapping out the pair of 6510's for a 6503 stereo woofer & one 6511 dimensional woofer then finding or building a correct 2B XO ??
  • FestYboy
    Viking64 wrote: »
    FestYboy wrote: »
    Tweets only
    I should have prefaced it by saying I've never seen anyone TL mod and make mention of having to replace the MWs as well.
    Now, given the model # you have listed, that would mean that the TL MW would have predated any TL speaker by over a decade. Something is amiss.
    pitdogg2 Posts: 27,334
    ThomasD wrote: »
    Toolfan66 wrote: »
    No need to swap MW drivers. This is all about the tweeter section
    FestYboy wrote: »
    I just did further research and I found several pre-TL speakers listed as having various model numbers of tri-laminate mids. And not just in text that was typed by a person listing things, but actual text from brochures, etc.
    Viking64 wrote: »
    FestYboy wrote: »
    Tweets only
    Marketing speak for the dopped paper cones. The tweeter have vapor deposited metal on the domes hence tri-laminated.
    So, they used the term "tri-laminate" for 5 years strictly as a marketing tool until they finally actually used a true tri-laminating process on their tweeters starting in 1989?
  • ThomasD
    ThomasD Posts: 260
    ThomasD wrote: »
    Toolfan66 wrote: »
    Well, I was referring to actually transforming the 2A's into 2B's/CRS+ first, then adding the SL3000 with any necessary XO upgrades to follow along with the planned Polk "published schematic" that @F1nut was mentioning. I mean would this keep things on a more 'authentic' track?
    ThomasD wrote: »
    ThomasD wrote: »
    Toolfan66 wrote: »
    Then buy 2b's. Switching out all but the cabinet is crazy talk.
  • ThomasD
    ThomasD Posts: 260
    I certainly don't disagree. But available Polk SDA's are few and far in between here.
    F1nut Posts: 52,008
    Toolfan66 wrote: »
    I can't agree with that. The 2A and 2B use different drivers with different cap and inductor values. Not to mention there is an extra resistor in the 2A tweeter circuit.
    The overall balance has to be considered because it will be affected.
    Toolfan66 wrote: »
    Not if you find the drivers you need, sell the original drivers, buy a set of gimpods boards, buy the necessary XO parts, a pair of RDO 198’s and rock on, you’re not really out anymore if you upgraded a set of 2B’s...
