Blackhole 5
ThomasD
I’ve looked through all the threads. Only places that I could find listed as distributors were Sonic Craft & Parts Express. I can’t find it even listed in either of their websites. Has the product name changed? Does it still exist? Acceptable substitutes? What am I missing?
Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Good luck. BH5 that everyone raves about is discontinued. You may find some extra slivers here on CP as I did, but Parts Express has a substitute (not as good as BH5, but still good stuff) called Sonic Barrier, IIRC.
Have fun on your journey!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
So I'm not going mad !!!! I saw the Sonic Barrier with PSA backing but wasn't sure if there was something better. The Blackhole website still shows the 5 but not that it's available anywhere. Any other recommendations ?Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Nope you're not going mad! I couldn't wait so I bought a sheet of Sonic Barrier and then some BH5 showed up on the classifieds here so I snatched it up. I Karma'd the Sonic Barrier to a buddy.
Sonic Barrier will work just fine. I used it in several builds, no issues.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Did you use the 3 layer? Looks like a couple different styles.Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Yep 3-Layer. 1.25" thick.
And how about using the Sonic version for a Dynamat Extreme equivalent on speaker baskets?Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Yes!! To add the adhesive is excellent.Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Yes, get the 1 1/4" thick stuffGustard X26 Pro DAC
I went with the status quo here and used the Dynamat Extreme.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I haven't been able to find any place that will sell & ship the small 10" x 10" Dynamat pads to Alaska. Strange as it sounds. That's why I was wondering about the Sonic Barrier Equivalent. PE seems to ship here.Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM -
Dang dude Alaska! I understand your conundrum!
Us Midwest Polkies lament on the abundance of good stuff for sale in CA!
Shipping anything up here, small or large is almost always a challenge.Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Blackhole 5 is still available, but it come in smaller sheets and costs a lot more. Still, nothing else really comes close.
Do NOT use Blackhole 5 or Sonic Barrier on the driver baskets. Those products and Dynamat Xtreme have very different purposes.Political Correctness'.........defined
President of Club Polk -
Blackhole 5 here, http://www.speakercity.com/Merchant2/merchant.mvc?Store_Code=sc&Screen=PROD&Product_Code=damping-bh5Political Correctness'.........defined
Perhaps I misspoke. I do understand the difference between the two. Sonic Barrier MX-4 Max Aluminum Foil Butyl Foam Rubber Sound Damping Sheets seem to be similar to the Dynamat Xtreme for using on the driver baskets. Where is the Blackhole 5 available at?
Dynamat Xtreme does not have foam rubber in it.
BH5 is in the link I posted.Political Correctness'.........defined
Jesse there is dampening stuff that does have a thin foam back. I have not used it but my local car shop quit carrying the second skin stuff i used on my first project and went to the foam backed stuff. This was because second skin was trying to get them to order large drop shipments they would use in 5 yrs.
Second skin is like dynamat that has thicker aluminium side and thicker butyl side. -
Yep, it was expensive ($92 incl. shipping) for a 12"x18" piece of BH5. That's $800+ into these speaks so far. I've read several of the threads for placement of the dampening material. What's the final consensus on size and placement of the BH? Just behind the Mid driver?Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM -
Yep. Behind the MW only.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
4"x8" or 8"x8" or larger?Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
I did 4” x 12” strips on my 1Cs. Located vertically right behind the MWs. BTW I’m happy you found some BH5 thanks to @F1nut !Post edited by verb onBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Yes, thanks to @F1nut, he is responsible for that. No google search brought up Speaker City as a source. So the dampening material should be wider horizontally than vertically?
Sorry @ThomasD I placed mine vertically behind the MWs as there is a structural brace in the middle of the cabinet.
Just place the BH5 right behind the MWs. I used 4” strips. Length wise they went from the top of the upper MW basket to the bottom of the lower MW. Outside diameter to outside diameter.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Got ya. I only have 1 MW with my 7's, so it will not be a large piece of BH. Locktite for the adhesive? If I can ever aquire a pair of SDA's then I'll have some more MW's to contend with.Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
You still use the polyfil in the speaker with bh5
Thanks @verb. Was just looking through some previous threads and I see that @westmassguy and some others of you have helped another Northern SDA project on the forum recently ( @TheChemist ).Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
Yes, any special way to tuck that in or just make sure the tweet is isolated from the mid? At least I assume that's the intent. Correct me if I'm wrong.Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM -
I've never had monitor 7 but on my sda2 and sda 1a it was behind both mw and tweeter nothing behind passive.
In their current state the batting is just behind the tweets. Guess I'd better get a definitive ruling on this issue.Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
