Blackhole 5
I’ve looked through all the threads. Only places that I could find listed as distributors were Sonic Craft & Parts Express. I can’t find it even listed in either of their websites. Has the product name changed? Does it still exist? Acceptable substitutes? What am I missing?
Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
  • verb
    verb Posts: 10,176
    Good luck. BH5 that everyone raves about is discontinued. You may find some extra slivers here on CP as I did, but Parts Express has a substitute (not as good as BH5, but still good stuff) called Sonic Barrier, IIRC.
    Have fun on your journey! :smile:
  • ThomasD
    ThomasD Posts: 260
    So I'm not going mad !!!! I saw the Sonic Barrier with PSA backing but wasn't sure if there was something better. The Blackhole website still shows the 5 but not that it's available anywhere. Any other recommendations ?
  • verb
    verb Posts: 10,176
    ThomasD wrote: »
    Nope you're not going mad! I couldn't wait so I bought a sheet of Sonic Barrier and then some BH5 showed up on the classifieds here so I snatched it up. I Karma'd the Sonic Barrier to a buddy. :smile:
  • RandyCroissant
    Sonic Barrier will work just fine. I used it in several builds, no issues.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • ThomasD
    ThomasD Posts: 260
    Did you use the 3 layer? Looks like a couple different styles.
  • verb
    verb Posts: 10,176
    Yep 3-Layer. 1.25" thick.
  • ThomasD
    ThomasD Posts: 260
    And how about using the Sonic version for a Dynamat Extreme equivalent on speaker baskets?
  • RandyCroissant
    Yes!! To add the adhesive is excellent.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
    audioluvr Posts: 6,014
    Yes, get the 1 1/4" thick stuff
  • verb
    verb Posts: 10,176
    ThomasD wrote: »
    I went with the status quo here and used the Dynamat Extreme.
  • ThomasD
    ThomasD Posts: 260
    verb wrote: »
    ThomasD wrote: »
    I haven't been able to find any place that will sell & ship the small 10" x 10" Dynamat pads to Alaska. Strange as it sounds. That's why I was wondering about the Sonic Barrier Equivalent. PE seems to ship here.
  • verb
    verb Posts: 10,176
    Dang dude Alaska! I understand your conundrum! :smile: Us Midwest Polkies lament on the abundance of good stuff for sale in CA! :smile:
  • ThomasD
    ThomasD Posts: 260
    Shipping anything up here, small or large is almost always a challenge.
    F1nut Posts: 52,166
    Blackhole 5 is still available, but it come in smaller sheets and costs a lot more. Still, nothing else really comes close.
    Do NOT use Blackhole 5 or Sonic Barrier on the driver baskets. Those products and Dynamat Xtreme have very different purposes.
    F1nut Posts: 52,166
  • ThomasD
    ThomasD Posts: 260
    Perhaps I misspoke. I do understand the difference between the two. Sonic Barrier MX-4 Max Aluminum Foil Butyl Foam Rubber Sound Damping Sheets seem to be similar to the Dynamat Xtreme for using on the driver baskets. Where is the Blackhole 5 available at?
    F1nut Posts: 52,166
    Dynamat Xtreme does not have foam rubber in it.
    BH5 is in the link I posted.
    pitdogg2 Posts: 27,580
    Jesse there is dampening stuff that does have a thin foam back. I have not used it but my local car shop quit carrying the second skin stuff i used on my first project and went to the foam backed stuff. This was because second skin was trying to get them to order large drop shipments they would use in 5 yrs.
    Second skin is like dynamat that has thicker aluminium side and thicker butyl side.
  • ThomasD
    ThomasD Posts: 260
    Yep, it was expensive ($92 incl. shipping) for a 12"x18" piece of BH5. That's $800+ into these speaks so far. I've read several of the threads for placement of the dampening material. What's the final consensus on size and placement of the BH? Just behind the Mid driver?
  • verb
    verb Posts: 10,176
    Yep. Behind the MW only.
  • ThomasD
    ThomasD Posts: 260
    4"x8" or 8"x8" or larger?
  • verb
    verb Posts: 10,176
    edited April 2018
    I did 4” x 12” strips on my 1Cs. Located vertically right behind the MWs. BTW I’m happy you found some BH5 thanks to @F1nut !
    Post edited by verb on
  • ThomasD
    ThomasD Posts: 260
    Yes, thanks to @F1nut, he is responsible for that. No google search brought up Speaker City as a source. So the dampening material should be wider horizontally than vertically?
  • verb
    verb Posts: 10,176
    Sorry @ThomasD I placed mine vertically behind the MWs as there is a structural brace in the middle of the cabinet.
    Just place the BH5 right behind the MWs. I used 4” strips. Length wise they went from the top of the upper MW basket to the bottom of the lower MW. Outside diameter to outside diameter.
  • ThomasD
    ThomasD Posts: 260
    Got ya. I only have 1 MW with my 7's, so it will not be a large piece of BH. Locktite for the adhesive? If I can ever aquire a pair of SDA's then I'll have some more MW's to contend with.
    You still use the polyfil in the speaker with bh5
  • ThomasD
    ThomasD Posts: 260
    Thanks @verb. Was just looking through some previous threads and I see that @westmassguy and some others of you have helped another Northern SDA project on the forum recently ( @TheChemist ).
  • ThomasD
    ThomasD Posts: 260
    Yes, any special way to tuck that in or just make sure the tweet is isolated from the mid? At least I assume that's the intent. Correct me if I'm wrong.
    I've never had monitor 7 but on my sda2 and sda 1a it was behind both mw and tweeter nothing behind passive.
  • ThomasD
    ThomasD Posts: 260
    In their current state the batting is just behind the tweets. Guess I'd better get a definitive ruling on this issue.
