SVS SB1000 or Rhthmik L12 Direct Servo subwoofer?
Around the same price which one do yall like?
I hate this tablet
I hate this tablet
I’m thinking you’ve reached the point where people are afraid to open your posts.
I disabled, I am the South Carolina woman who gouged her eyes out on meth.
Theater:
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Velodyne has them, but it appears to me they are going out of business, which would be a damn shame because their Optimum and DD Plus subs cover all the bases. JL Audio has high levels on their two lower models, but they aren't binding posts just some sort of BS bare wire connections and no calibration/DSP. Rythmik has them, but damn their subs are homely and again, no calibration/DPS.
I thought the same thing about the JL with its cheesy connector for its high level inputs. But it’s small connector is actually nice, I built a nice cable using Mil spec silver over copper wire with tech flex and heat shrink. Spades on the amp end, and if you need to re-configure your set-up is can easily be unplugged.
JL does use calibration software, which unfortunately is only used on their F series subs, which are expensive, but can be had for a good price on the used market.
Too bad about velodyne, didn’t know they were in trouble.
Theater:
@F1nut I would like to have a pair of them eventually. The longer I wait to get one, the longer I wait to get two. My guess is I am better off following Ron's suggestion so any sub is way over the horizon. Anyway with economy in mind which do you think will sound better out of anything that you can think of?
I take it you used bare wire at the sub end?
In reference to JL's calibration software is it called something specific?
Theater:
http://www.whatsbestforum.com/showthread.php?21597-What-is-the-most-musical-fast-and-accurate-subwoofer-you-have-heard
In case anyone is wondering, the OP, our very own treitz3 ended up buying a pair of Rythmik F25's.
I bought this sub on the forums a while back: http://www.m-audio.com/products/view/bx-subwoofer
While it hit hard and went low, I found it to be slow and sloppy with plenty of port noise/chuffing.
I did indeed. While I can not speak for the model afterburnt is inquiring about, my purchase of the pair of F25's is slated in my mind as one of the top 5 audio purchases I have made in my lifetime. If you know me, you will know that I have been through quite a lot of gear over the decades.
I think (just my opinion) that it isn't so much the name brand of the sub (referring to Ryhtmik) that makes it special, I think honestly that it's the direct servo technology. THIS is what I think makes the Rythmik subs. If you have not heard it yet, you owe it to yourself to hear one....from any manufacturer. Tight, accurate, powerful, precise *NO boom at the bottom whatsoever* and because of these quality traits, it makes them very easy to blend in with the rest of the system. I say this from experience with 2 direct Servo subs on 2 different systems I had to dial in.
Your headed in the right direction in choosing a sealed sub for Rythmik as well, FWIW.
While I have not heard either of the subs you have on your list, I am very familiar with both companies and their offerings over the years. If this were a decision that was up to me? I would choose the Rythmik. Not because of the name brand but because of the technology. Good luck with whatever it is you end up purchasing.
~ The best way to enjoy digital music reproduction is to never listen to good analogue reproduction ~
~ When the law ends, tyranny begins ~
The servo setup has never let me down vis-a-vis "keeping up" with any signal I throw at it, music or HT-wise.
2 Channel Studio: Marantz PM8004 Integrated ; Marantz SA8004 ; Music Hall MMF 7.3TT w/Ortofon Bronze; Schiit Bifrost DAC ; Monitor 7 Series 2 with RDO 198s; Rythmik F12SE
Don't cry
Don't raise your eye
It's only teenage wasteland
John, I know they make great subs and have a lot of manual adjustments for dialing them in. I don't know if manual or auto calibration/DSP is better than the other, but I do know the auto is easier.
I also know Rythmik has put most of their money into the performance, I just wish they would spruce up the cosmetics and offer remote control. I think people buying a quality sub wouldn't mind paying a bit more to get a bit more.
Velodyne never returned my 3 calls last week, so I sent them an email asking if they were going out of business. Wonder if they will respond?
Alas, they have hit their niche market and nailed it. Price to performance.
That's not the reason I went Salk cabs. But, I sure am glad I did!
PS Audio PerfectWave Power Plant 10
Rears Salk SuperCharged Surrounds
Source PSA PWT into NSD Supremo
Pre/Pro Integra DHC 40.1
LCD Samsung LN46B750
Mains Salk HT2-TL
Center Salk HT2C
Pre Cary SLP-05
Wires WW & MIT
https://www.minidsp.com/products/dirac-series/ddrc-24
or
https://www.minidsp.com/applications/digital-crossovers/subwoofer-integration-with-minidsp
I had Jim Salk build a custom cabinet to match my mains. I believe the only sub components/electronics he uses are Rythmik
http://salksound.com/model.php?model=Rythmik+15+Subwoofer
Mains Salk HT2-TL
Center Salk HT2C
Pre Cary SLP-05
Wires WW & MIT
I’ve long toyed going w Dirac and the next buying a older Marantz AVR w preouts as I’d not need to worry about what version of Audyseey it has.
But I don’t think Dirac works w HDMI 2.0 or HDCP 2.w...
With that said, it's an all in one unit when it comes to Direct Servo. Anything less is garage Cerwin-Vega type stuff. There is NO DIY with Direct Servo.
FWIW.
Hmmmm.......interesting, thanks.
Been a while since I spoke of why my interests peaked adding subs to even systems with large speakers. It was 2013 at RMAF 2013 and a great presentation of Wilson Audio's TOTL Alexandria's paired with their Thor's hammer sub's. You would ask why?? At the time I was a 2chnl, 2 speaker guy, but after the demo got me wanting more.
Speakers should still be purchased according to size of room. Although the Alexandria's can dig deep on their own, when properly set up there's always that little more you can add to that live experience.
Anyway back to my endeavor that never finished out. I'd bought the Dyn C4's and wanted to add 2 Rythmik 15's. I wanted the blend to be perfect for the room which was going to be 16x21. I was originally looking at JL audio CR1, Pass Labs XVR-1 crossovers for the system.
I reached out to Rythmik due to reviews and they are also based in Texas. Enrico was great to speak with and very knowledgeable...here's one of his emails
Ron,
I would hold on the CR-1 until you try the subwoofers with the onboard controls. The C4s play down to 30Hz but I would crossover around 50Hz to take some stress out of the speakers. In that case you can send full range signal to the speakers and full range signal to the subwoofers and set the low pass filter on the subwoofer at 50Hz/24 and the crossover on the subwoofer at 50Hz as well in order to get 50Hz with 24dB/octave slope. Then set proper delay/phase on the subwoofers. If you like the results, which I know you are gonna love it, you can save $3000 on the CR-1.
Another option a little bit cheaper but IMHO more effective than the CR-1 is the miniDSP DDRC-88A which come with Dirac Live room correction system and can handle up to 8 channels. In your case you can have the two C4s + the pair of subwoofers and set delay/phase, levels and EQ for each one independently. The miniDSP DDCR-88A is $1000.
https://www.minidsp.com/products/dirac-series/ddrc-88a
Best Regards,
Enrico Castagnetti
Just thought I'd share
--Cheers
Ron
Can't argue with you about the looks, and know you're not a piano black dude, though I do feel that's the "looker" in their line.
Interesting point about more "goodies". They do offer a lower end line (e.g. L12 vs. F12) so maybe they should consider another higher end line for those willing to splurge a bit.
Don't cry
