PSW202 interconnect
Hello, I just bought a PSW202. I found there are no Y-adaptor include in the box. I try to find one from Monster Cable. However I didn't see which one is Y-adaptor for subwoofer. Please help to suggest one to connect the PSW202 and my Onkyo receiver.
Thanks a lot.
L
Post edited by lomein123@hotma on
  • danger boy
    danger boy Posts: 15,722
    edited November 2004
    you don't need a Y adaptor. you can connect it with just one RCA cable input from your receiver.
    PolkFest 2012, who's going>?
  • Willow
    Willow Posts: 11,340
    If you want one make sure it has a female to 2 males
  • Toxis
    Toxis Posts: 5,116
    it'll work by having just one RCA in on the sub but if you add the Y-adapter, it'll give you anywhere from 3 to 10db in boost.
    In contrary to what Monster Cable might want to sell you, any Y-adapter will work. Just depends on what cable you're running as to what adapter to get. Better sub cable, I'd run a better adapter so you don't have as much loss in signal quality.
    http://www.monstercable.com/productPage.asp?pin=654 For the nice cable
    or
    http://www.monstercable.com/productPage.asp?pin=662 For the entry level cable.
  • dorokusai
    dorokusai Posts: 25,640
    www.half.com is an often forgotten place to look for cable deals....I've found a few on there that were just plain silly.
  • lomein123@hotma
    lomein123@hotma Posts: 2
    Thanks for the info.
    My subwoofer has two RCA input, one is labeled L, one is labeled R. Is that mean if I just use one, I only lost 3 to 10db in boost?
    Also the input on my receiver also need a Male interconnect. So it looks like I need 1 male to 2 males. Why all the the Y-adaptor from Monster are 1 female to 2 males? Do I need something else?
    thanks for the help.
  • dorokusai
    If you were to shop for a Y adapter, buy a "RCA Female to 2 RCA Male" adapter.
    A Y adapter is not neccessary....just a signal gain for sleepy subwoofers and a minimal gain in db overall.
    Get one cheap and sleep well if you are so inclined....but you won't be ending the world if you don't.
