PSW202 interconnect
lomein123@hotma
Hello, I just bought a PSW202. I found there are no Y-adaptor include in the box. I try to find one from Monster Cable. However I didn't see which one is Y-adaptor for subwoofer. Please help to suggest one to connect the PSW202 and my Onkyo receiver.
Thanks a lot.
L
Thanks a lot.
L
Post edited by lomein123@hotma on
you don't need a Y adaptor. you can connect it with just one RCA cable input from your receiver.PolkFest 2012, who's going>?
If you want one make sure it has a female to 2 males
it'll work by having just one RCA in on the sub but if you add the Y-adapter, it'll give you anywhere from 3 to 10db in boost.
In contrary to what Monster Cable might want to sell you, any Y-adapter will work. Just depends on what cable you're running as to what adapter to get. Better sub cable, I'd run a better adapter so you don't have as much loss in signal quality.
http://www.monstercable.com/productPage.asp?pin=654 For the nice cable
or
http://www.monstercable.com/productPage.asp?pin=662 For the entry level cable.Never kick a fresh **** on a hot day.
Car Setup: OEM Radio, RF 360.2v2, Polk SR6500 quad amped off 4 Xtant 1.1 100w mono amps, Xtant 6.1 to run an eD 13av.2, all Stinger wiring and Raammat deadener. -
www.half.com is an often forgotten place to look for cable deals....I've found a few on there that were just plain silly.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Thanks for the info.
My subwoofer has two RCA input, one is labeled L, one is labeled R. Is that mean if I just use one, I only lost 3 to 10db in boost?
Also the input on my receiver also need a Male interconnect. So it looks like I need 1 male to 2 males. Why all the the Y-adaptor from Monster are 1 female to 2 males? Do I need something else?
thanks for the help. -
If you were to shop for a Y adapter, buy a "RCA Female to 2 RCA Male" adapter.
A Y adapter is not neccessary....just a signal gain for sleepy subwoofers and a minimal gain in db overall.
Get one cheap and sleep well if you are so inclined....but you won't be ending the world if you don't.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
