XLR for P5 and A23
I have the P5/A23 combo integrated into my HT. Will XLRs give me a gain in performance? I’m currently using Douglas Connection Bravo ICs which made a significant improvement over some old monster ICs?
Regardless I need another set of ICs and could repurpose the Bravos. So should I consider XLRs and if so what should I look for in 200 or less range. Or should I get more Bravos?
Thanks,
RB
Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables
  • kharp1
    kharp1 Posts: 3,453
    A lot of the supposed gains, or lack there of, are widely disputed. I had the P5 and A21 for a bit and did use the balanced connection, and, the one thing for certain is thee wa an increase in gain with XLR.
  • rburgess714
    rburgess714 Posts: 618
    edited April 2018
    kharp1 wrote: »
    Any recommendations for xlr cables in the 200 or less range?
    Living Room
    Office
  • michaeljhsda2
    michaeljhsda2 Posts: 2,200
    SDA SRS 2.3TL's
    SDA 2B TL's
    tonyb Posts: 33,072
    If your happy with the cables from Doug, why change ? Have him make ya a set and be done.
  • rburgess714
    tonyb wrote: »
    For sure if I am staying with RCAs. I just did not know if XLR made a big difference and they are a bit more expensive so I was going to shop on the used market.
    Living Room
    Office
  • rburgess714
    tonyb wrote: »
    Okay I I goofed, they really are not that much more. I will be ordering a pair from Doug.
    Living Room
    Office
  • steveinaz
    steveinaz Posts: 19,545
    I really like Signal Cables XLR's, and recently bought a set ($59) for my Preamp to amp connections.
  • steveinaz
    FWIW, those $59 (2ft/pr) of XLR's replaced a $329 Kimber Hero WBT's RCA set and sound every bit as good, if not better than the Hero.
  • rburgess714
    edited April 2018
    steveinaz wrote: »
    Thank you sir. I ordered a pair from Doug yesterday so I am set for now.
    Living Room
    Office
