Question regarding bi-amping speakers per Polk manual.SDA SRS 2.3
bassfann
According to the original Polk literature, the 2.3 speakers do NOT need an electronic crossover,or even an ai-1 to biamp them. I know many feel different about it. What is the reason behind it.
You better read that again.Political Correctness'.........defined
President of Club Polk -
I use a common ground amp with 5 channels to bi amp mine. Has workwd for years. No external xover and no dreadnaught.Too much **** to list....
deleted
Idolizing a politician is like believing the stripper REALLY likes you. -
Of course, you're not actually bi-amping.Political Correctness'.........defined
You better read that again.You better read that again.
I read it on polksda.com. Which part is incorrect ?You better read that again.
You're generalizing things that shouldn't be and leaving out important information.
Yes, you can pseudo bi-amp those speakers, but it's not true bi-amping unless you use active crossovers. You can pseudo bi-amp any pair of speakers with two sets of binding posts.
This is the important information, "The low frequency amplifier must be common ground unless the AI-1 adaptor is used."
Post edited by [Deleted User] onPolitical Correctness'.........defined
Can I bi-wire without the ai-1 ? Reason I’m asking is I’m running a Bryston 8b 4 channel amp.
Can I bi-wire without the ai-1 ? Reason I’m asking is I’m running a Bryston 8b 4 channel amp.This is the important information, "The low frequency amplifier must be common ground unless the AI-1 adaptor is used."
^^^^ This....
"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
what about bi-wiring ?
If the amp is common ground, yes.
