Question regarding bi-amping speakers per Polk manual.SDA SRS 2.3
According to the original Polk literature, the 2.3 speakers do NOT need an electronic crossover,or even an ai-1 to biamp them. I know many feel different about it. What is the reason behind it.
    F1nut Posts: 52,001
    You better read that again.
  • SDA1C
    SDA1C Posts: 2,072
    I use a common ground amp with 5 channels to bi amp mine. Has workwd for years. No external xover and no dreadnaught.
    Too much **** to list....
  • motorhead43026
    motorhead43026 Posts: 4,031
    edited March 2018
    deleted
    – Kevin Alfred Strom
    F1nut Posts: 52,001
    SDA1C wrote: »
    Of course, you're not actually bi-amping.
  • bassfann
    bassfann Posts: 151
    I read it on polksda.com. Which part is incorrect ?
    F1nut Posts: 52,001
    edited March 2018
    You're generalizing things that shouldn't be and leaving out important information.
    Yes, you can pseudo bi-amp those speakers, but it's not true bi-amping unless you use active crossovers. You can pseudo bi-amp any pair of speakers with two sets of binding posts.
    This is the important information, "The low frequency amplifier must be common ground unless the AI-1 adaptor is used."
  • bassfann
    bassfann Posts: 151
    Can I bi-wire without the ai-1 ? Reason I’m asking is I’m running a Bryston 8b 4 channel amp.
  • TNTsTunes
    TNTsTunes Posts: 751
    bassfann wrote: »
    ^^^^ This....
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • bassfann
    bassfann Posts: 151
    TNTsTunes wrote: »
    bassfann wrote: »
    ^^^^ This....
    what about bi-wiring ?
  • monepolk
    monepolk Posts: 1,154
    If the amp is common ground, yes.
