Vintage Monitor and SDA Speaker Deals
My tweeters aren't that color in mine. Mine are all black. But my top and bottom plates are veneer and not black like his. And he's only got a picture of one.Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra -
dkfreebird wrote: »I inquired about the McCormack I spotted on the floor but it was a no go.
I saw that McCormack on the floor also. Too bad.
I have the walnut veneer on mine.My tweeters aren't that color in mine. Mine are all black. But my top and bottom plates are veneer and not black like his. And he's only got a picture of one.
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Have you pulled the tweeters to see if they are rdo’s?2 Channel
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
dkfreebird wrote: »Have you pulled the tweeters to see if they are rdo’s?
No need to pull just look for the foam ring around the dome. No foam RDO. foam SL3000.
More than likely the RDO may not be marked as such. IIRC early versions had no markings.
Some SL3000 had a blackish dome. -
Yep,forgot about that.
Eversolo Dmp 8
SVS SB3000 sub
Oppo 103
Pangea PC
They do have the rare Walnut caps though.Most people just listen to music and watch movies. I EXPERIENCE them.
Nice looking set of 1Cs, about an hour from me. Looks like a good buy at $375.
https://www.ebay.com/itm/POLK-AUDIO-SDA-1-1C-SPEAKERS-VERY-NICE-WITH-ORIGINAL-INTERCONNECT-ONE-OWNER/173225426047?hash=item28550a3c7f:g:l1wAAOSwn35arDdQSDA SRS 2.3s
Pair of Carver TFM 35s
Carver C-1 Preamp
CAL Icon MkII CD
RTA 12s, need major work -
They went quick!
Noticed this while looking at that...
https://m.ebay.com/itm/POLK-AUDIO-RTA-8T-MONITOR-SERIES-Tower-Speaker-Pair-Demo-Vid/112815131031?_trkparms=aid=555018&algo=PL.SIM&ao=2&asc=50524&meid=3003b10e8e98444383c539b17e6f3bd4&pid=100890&rk=2&rkt=12&sd=173225426047&itm=112815131031&_trksid=p2056116.c100890.m2460
Someone needs to put down the crack pipe -
I was going to look at these today, but decided I don't have a place for them.
https://stlouis.craigslist.org/ele/d/polk-lf14-passive-subwoofers/6536413629.html
That's a smoking deal!!! I might be tempted to go halves with someone right there. -
From the pictures they look to be in good condition. Just don't want to store any more speakers.
Yeah you have to do something about that.
@la2vegas , you only use one...
What a tease: https://www.ebay.com/itm/Wilson-Audio-Sophia-Piano-Gloss-Black-Speakers/323143768632
Forget the Wilsons, what about those SDAs in the background?!
Well, seeing as I own one... yeah, I'm right
They can also be used in pairs, but that's probably gonna be too much bass unless you're running 4s. -
I'm being tormented. These SRT's are local, and did not sell. They are relisted. Still 35 Hundie.
https://www.ebay.com/itm/173225627435?ViewItem=&item=173225627435Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Go in with an offer... Worst they can say is no...
1500.00 CASH
$1.87, final offer.
$0.00187? Hard to split a penny like that but I'll give it a try.
Lincoln's nose should do it.
I love proof-70 coins!!!
And yet you look right past the ML Amp sitting right there. Wondering if it is a mono? Can't make out the model number -
Yes mono's No.53's2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
What amp? That's a space heater!
Ah, they were listed here but they didn't sell: https://www.ebay.com/itm/Polk-Audio-Reference-SDA-SRS-1-2-/391989880811
Probably don't run that hot. My Pass XA30.5 put off more heat the Threshold Stasis SA12e monoblocks. More heat sync dissipation2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Looks like somebody’s buyer flaked out on them. Go for it @la2vegas
https://m.ebay.com/itm/POLK-AUDIO-SDA-SRS-ll-SPEAKERS-MINT/253509900322?_mwBanner=1&ul_ref=https://rover.ebay.com/rover/0/e11011.m43.l1123/7?euid=af597f4652fc4d16a0f72e3b6cfb08fc&bu=43021743341&loc=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F253509900322&sojTags=bu=bu&srcrot=e11011.m43.l1123&rvr_id=0&ul_noapp=true2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s
