I need a new wireless router any recommendations?
gudnoyezgudnoyez Posts: 7,048
https://www.bestbuy.com/site/google-google-wifi-ac1200-dual-band-wi-fi-router-white/5706129.p?skuId=5706129
I think our 10 year old Cisco wireless router is on its last leg, connections are starting to be spotty and speeds are all over the place. Don't want to spend over $200, I guess getting 10 years out a the Cisco was pretty good. I'm looking at this Google one is this recommended or should I be looking for another brand?
  • mdaudioguymdaudioguy Posts: 5,082
    I like my Netgear Nighthawk router - good speed, strong signal - seems to be robust.
  • rooftop59rooftop59 Posts: 5,968
    I have the google mesh system, which is basically three of those units u are looking at. It works GREAT! But I have three in a 3000 sq ft u shaped home. I think one would work fine in a small home, say 1000-1500 ft. But bigger than that I’m not sure if one would cover it...
    One thing to note is that you don’t have any many options with the google as the netgear. For instance, u can’t use a VPN with google. That doesn’t matter to me but ymmv...
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio NovaPre; B&K TX4430; Bryson BPD-1; Mains: Dynaudio Excite x18; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - HSU VTF-2 MK5; LG UP870 4K BDP; NVidia ShieldTV
    Master Bedroom
    Cambridge Azur 551r; Definitive Technology SM45, NHT Super One CI surrounds, Martin Logan Dynamo (original), Squeezebox Touch
  • IrrenhausIrrenhaus Posts: 860
    How about Asus RT-AC1900, I currently have the RT-AC68R and it's been great.
    Cheers
    HT
    AVR-Pioneer SC99
    Adcom 585
    RTi12s
    Rear- RT150
    Center-CSi5
    Sub-Rythmik audio F25
    Player- Oppo BDP-103
    Living room 2ch rig:
    Peach Tree Decco, Onkyo CS-5VL SACD and Linn Kelidh
    Bedroom 2ch rig.
    Cary AE-3, Parasound 2125, Marantz SA8005, Usher V-601 or SDA 1C, SVS SB12-NSD, Intel NUC PC and Panamax MX5105
    Headphone rig;
    Little DOT MK II with upgraded tube's and Sennheisers HD650.
    Irrenhaus wrote: »
    Yes, my other router is an Asus - like that one too!
  • gudnoyezgudnoyez Posts: 7,048
    Thanks for the advice ended up getting a Netgear Nighthawk AC2300 on sale with $20 off at Best Buy it cost 179.99. So saving 20 on a 200 router sounded good to me I hope it is a good one. I got 9 years out of the old one.
    Hooked it up man its blazing fast should of replaced the old one long ago. If any of you computer gurus can answer this what's the difference between NETGEAR30, and NETGEAR30-5G? When I search for networks, both of these options show up.
  • AsSiMiLaTeDAsSiMiLaTeD Posts: 11,717
    It looks like that router allows you to have separate names for the 2.4 and 5Ghz bands, that can come in handy if you run devices like the Aries that tend to prefer a 5G network. In general, the 5.0 band gives you faster speeds but doesn't have the range of a 2.4...so my other general rule is to use the 5Ghz unless you can't
    Thanks for the advice I appreciate it.
    Mine is an older AC1750. Still blazing fast. You should be good to go with that!
  • NightfallNightfall Posts: 8,484
    5GHz should theoretically give you more bandwidth but the shorter wave length doesn't penetrate walls as well. Much like treble vs bass, you can hear bass from blocks away when that riced out Civic drives by your house but you can't hear the treble until they're on top of you.
    afterburnt wrote: »
    Village Idiot of Club Polk
Howdy, Stranger!
