PS Audio AC12 Power Cable 2M
Or similar cable for my sub....need something somewhat flexible due space contraints.
  • GlennDog
    GlennDog Posts: 3,152
    That's been a very good cable for me (connected to my sources)
    If I found 2 more, my monos would be the better for it
    Flexible? Not so much
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
    EndersShadow Posts: 17,705
    edited March 2018
    The AC12 is by NO MEANS flexible. The AC-3 is a better alternative.
    I'm running them exclusively in both setups except for my HTPC which is using a Signal Cable Digital Reference
  • motorhead43026
    motorhead43026 Posts: 4,012
    X2 on the AC-3.
    – Kevin Alfred Strom
  • GlennDog
    Much more accurate than "not so much"
    But such a good cable, I'd consider moving the sub to accommodate the cable.
    I know there's a lot of reasons why that won't work. But, if we're talking man cave, maybe it will
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    I should probably list what they are on since my setup isnt in my signature (if there is even anything lol).
    These use a AC-3
    APC H15 x 2
    B&K 200.5
    Xbox One
    Crown XLS2000 x 2
    MiniDSP 2x4 Balanced
    Denon X4100w
    MicroPro 2000
    Anthem MRX500
    The ONLY IEC device that DOESNT have one is my HTPC which is using that Signal Cable Digital Reference.
    I do need to find some C7 cables for my NAS, Uverse DVR's and a few other misc devices.
  • kevhed72
    kevhed72 Posts: 5,146
    edited March 2018
    Correction....I am looking for an AC 3....the 12 awg cable. Also, Im wondering how flexible the Signal 10 awg power cable is (?)
    kevhed72 wrote: »
    Good to know....I thought this was their 12 awg cord and assumed it would be more flexible than the 8awg AC 3....unless I have that backwards
    AC-12
    PCOCC single crystal construction
    8 gauge power cable
    Quad shielded low noise
    Hollow tube conductors for treble performance
    Rectangular conductors for midrange performance
    Multiple gauge conductors for bass performance
    Gold plated connectors
    Welded connector to conductor
    Quiet for digital
    Unrestricted for analog
    AC-3
    Oxygen Free Copper (OFC)
    12 gauge power cable
    Single shielded
    Nickel plated connectors
