PS Audio AC12 Power Cable 2M
kevhed72
Or similar cable for my sub....need something somewhat flexible due space contraints.
That's been a very good cable for me (connected to my sources)
If I found 2 more, my monos would be the better for it
Flexible? Not so muchAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
The AC12 is by NO MEANS flexible. The AC-3 is a better alternative.
I'm running them exclusively in both setups except for my HTPC which is using a Signal Cable Digital Reference"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
X2 on the AC-3.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
EndersShadow wrote: »The AC12 is by NO MEANS flexible.
Much more accurate than "not so much"
But such a good cable, I'd consider moving the sub to accommodate the cable.
I know there's a lot of reasons why that won't work. But, if we're talking man cave, maybe it will
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
I should probably list what they are on since my setup isnt in my signature (if there is even anything lol).
These use a AC-3
APC H15 x 2
B&K 200.5
Xbox One
Crown XLS2000 x 2
MiniDSP 2x4 Balanced
Denon X4100w
MicroPro 2000
Anthem MRX500
The ONLY IEC device that DOESNT have one is my HTPC which is using that Signal Cable Digital Reference.
I do need to find some C7 cables for my NAS, Uverse DVR's and a few other misc devices."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Correction....I am looking for an AC 3....the 12 awg cable. Also, Im wondering how flexible the Signal 10 awg power cable is (?)EndersShadow wrote: »The AC12 is by NO MEANS flexible. The AC-3 is a better alternative.
Good to know....I thought this was their 12 awg cord and assumed it would be more flexible than the 8awg AC 3....unless I have that backwardsEndersShadow wrote: »The AC12 is by NO MEANS flexible. The AC-3 is a better alternative.
AC-12
PCOCC single crystal construction
8 gauge power cable
Quad shielded low noise
Hollow tube conductors for treble performance
Rectangular conductors for midrange performance
Multiple gauge conductors for bass performance
Gold plated connectors
Welded connector to conductor
Quiet for digital
Unrestricted for analog
AC-3
Oxygen Free Copper (OFC)
12 gauge power cable
Single shielded
Nickel plated connectors
