Conrad Johnson vs. Carver Amp
Glad you like it, but many of us knew the outcome ahead of time. Now when you hear someone say that amps don't matter much, you have a frame of reference to prove them wrong.
Older higher end pieces make excellent audio choices for those on a budget. Congrats again.
Oh, and get that amp off the carpet soon. Static isn't good for amps.HT SYSTEM-
lsi 9's -
Will do @tonyb ! Thanks!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Not on my list of reference CD's but hey maybe I'll give it a go! Thanks Jimmy!
Yeah, the sound quality leaves a lot to be desired.
Well I finally had a chance to make a stand for my CJ Amp. Prior to that, I just had it sitting on a scrap piece of maple butcher block. Even before that, yes it was sitting on the carpet!
I used 1.5" oak butcher block, and found the 1/8" steel legs on-line, designed for a chair or couch. There are 4 mounting holes per leg which I secured with screws. The feet are threaded which allows adjustment. Eventually I will replace them with spikes.
Looking very good
Hell yeah!
Sexy that wood is. Looks sturdy too.Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
Design inspired by Tom Swift's spaceship.
Yep. I can stand on it (~200 lbs) without any issue.
Kinda spacecraft looking, I'll admit. Heck, I just need a monoprice amp to launch this sucker into orbit!
Leg source please? I like the looks of those a lot better than some others I've used in the past.
Thanks Dave. Got em on eBay. Here's a link:
https://www.ebay.com/itm/4pcs-15cm-6-inch-Modern-Metal-Sofa-Legs-Couch-Table-Furniture-Cabinet-Feet-/132090920019?hash=item1ec13b7c53Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Good looking amp Dave!!!HT Speakers: Polk S15 * Polk S35 * RSL Speedwoofer 12S
https://www.youtube.com/watch?v=7OOfZs4M1YY
