Speaker jumper cables
2
  • F1nut wrote: »
    Doing this I have noticed a slight improvement in souls from kids and highs And highs.
    A tad too high me thinks.
    If that was only the case.
  • gp4jesus
    gp4jesus Posts: 2,019
    @ Firsttimer - I got that you have:
    a. replaced the jumper plates w/the AQ jw
    b. not upgraded the wire between your amp/AVR and speakers/woofer BPs.
    BUT...
    gp4jesus wrote: »
    Do you have any spare/leftover wire? Try it
    firsttimer wrote: »
    Yes I have left over wire... ...[I’ll*] try it maybe and see what happens.
    Did you get around to trying leftover wire, BEFORE installing the AQ jumpers?
    If you did try leftover wire, was the SQ, better, different, or no change?
    ...after two attempts you still haven’t answered my question.
    *all connected w/Premiere ICs
  • FestYboy
    FestYboy Posts: 3,861
    edited March 2018
    @gp4jesus just read the entire thread and as I understand it, @firsttimer went directly from the plates to the AQ jumpers. Now since you've asked technically 3 times, are you asking for his opinion, or just to see if you're "right" by just using leftovers and saving the $? If the latter, and you haven't tried higher grade dedicated jumpers yourself, maybe you should do it and form your own opinion and allow him to experiment within his comfort zone. Aslo consider this: your equipment may be vastly different than his, and therefore the results may very just as wildly, so the experiment's results may be moot.
    One last point, a bold or italicized is used for stress it's importance. In the realm of the interwebs, going bold (or ALL CAPS) is often used to connotate loudness, so bolding an entire sentence is akin to yelling it... It can be off putting to some.
    My $0.02
  • Thought I answered it every time. But here goes again. As fest said NO I did not use speaker wire. Went right to the AQ JUMPERS. Is that CLEAR ENOUPH. Have stated my opinion on doing this
  • [Deleted User]
    [Deleted User] Posts: 7,598
    I believe he means: " Doing this I have noticed a slight improvement in sounds from mids and highs".
  • I believe he means: " Doing this I have noticed a slight improvement in sounds from mids and highs".
    Correct
  • steveinaz
    steveinaz Posts: 19,546
    Just an FYI for the audio-anal, I prefer to bring my main wire in on the top posts, and jumper down to the woofer(s).
  • steveinaz wrote: »
    Might try that what is the benefit?
  • marvda1
    marvda1 Posts: 4,962
    Puritan PSM156
  • steveinaz
    firsttimer wrote: »
    steveinaz wrote: »
    I prefer having my better quality primary speaker cables going (directly) to the midrange/tweeter posts, then jumping "down" to the woofer posts. Does it help? I don't know---but it certainly doesn't hurt. The less connections you have to pass thru, the better.
    firsttimer wrote: »
    steveinaz wrote: »
    I have been trying this since the weekend and I do like the sound reproduction. Is it better/different hard to say but I thought no it does sound better
  • Thinks it sounds better damn spell check on my phone
  • DaveHo
    DaveHo Posts: 3,583
    steveinaz wrote: »
    firsttimer wrote: »
    steveinaz wrote: »
    Never gave it much thought, but that makes sense. If we have a snow day tomorrow, I might have to reverse the cables on my 705's and see what's up.
  • delkal
    delkal Posts: 764
    edited March 2018
    DaveHo wrote: »
    steveinaz wrote: »
    firsttimer wrote: »
    steveinaz wrote: »
    Not sure where you live but snowy days might not be the best time to test your system. We are going to get hammered here is SE PA.
    Once the trees start falling the power company will do anything it can to get you any amount of power. But not necessarily good power (think brownouts and Hz fluctuations)
    I already have my system unplugged.
  • DaveHo wrote: »
    steveinaz wrote: »
    firsttimer wrote: »
    steveinaz wrote: »
    Try it I am really liking it this way. Mids and highs seem a lot better to my ears. Seems to have opened them up.
  • steveinaz
    I'd rather have bass signals going thru a jumper than more articulate treble/midrange signals.
    txcoastal1 Posts: 13,519
    steveinaz wrote: »
    I like the idea
    Treble to me seems much more pronounced, same as midrange, cymbals a lot clearer. Thanks for the suggestion. I have the S60’s crossed at 60 hertz so a lot of the bass is going through my two subs anyways. Thanks again
  • marvda1
    edited March 2018
    anyone try the diagonal setup where the negative is on the left lower and the positive is on the upper right ?
    the hookup in the last diagram.
    http://www.nordost.com/downloads/NorseJumperinstructions.pdf
    Puritan PSM156
  • FestYboy
    If the jumpers are made of the same wire as the main leads, electrical theory says that their position/order doesn't matter. This is assuming a clean connection at all points. Corrosion/oxidation will obviously create a change.
    pitdogg2 Posts: 27,247
    marvda1 wrote: »
    Yes it sounded like snot on mine. It also shifted the image to the left.
  • FestYboy
    marvda1 wrote: »
    Now I'm curious, try throwing some deoxit at the posts and tips and see if there's a change.
  • steveinaz
    Eventually I'm going to get a set of Kimber 4TC to go on the treble/midrange, and move my 8TC down to the woofers; and eliminate the shorting plate completely.
    edited March 2018
    FestYboy wrote: »
    marvda1 wrote: »
    been there done that no it did not.
    Maybe when New XO's are in and new Cardas posts maybe....NOPE
    To be honest I may just put everything onto one set of posts and save some money on the 2 sets of Cardas instead of 4. I will never bi-wire or bi-amp anyway.
  • FestYboy
    Hmmm, so now the question is: what caused the change...? I'm not saying there's a need for a diagnosis, but...
  • K_M
    K_M Posts: 1,631
    Tie the leads to the High and low pass crossover together internally, and eliminate all the extra connections, and not spend a dime.
    Simple is usually best.
  • delkal
    delkal Posts: 764
    K_M wrote: »
    Thats what they did on all speakers for about 80 years before someone thought of Bi-wiring. And it worked. Makes you wonder why bi-wiring sounds better.
    I am about to recap a Monitor 10. Will it sound better if I put in 2 more binding posts and Bi-wire it?
    K_M wrote: »
    That is the plan Kelly
  • steveinaz
    Don't forget the other purpose of bi-wired bind posts.....for bi-amping. It's not a problem if you tie them together internally, just remember you won't be able to bi-amp.
