Another 1C upgrade path
1235»
  • verb
    verb Posts: 10,176
    Binding post caps with SpeakOn IC interface!
  • verb
    verb Posts: 10,176
    New Inductors!
  • verb
    verb Posts: 10,176
    New XO's! These things are works of art! Gimpod's boards are very well designed.zm16e9cr5jzh.jpg
  • verb
    verb Posts: 10,176
    Back side of XO's! Nice mounting board with double face tape to help secure plus attachment bolt. Solder joints are perfect!
  • verb
    verb Posts: 10,176
    My new IC Cable!
  • verb
    verb Posts: 10,176
    Last but not least. New attachment hardware!
    Clipdat Posts: 13,098
    You are going to have an amp that uses speakons?
    verb wrote: »
    My new IC Cable!
  • verb
    verb Posts: 10,176
    All I can say is WOW! These are the finest XO boards I have ever seen! It is clear to me that @westmassguy is an attention to detail kind of guy, and utmost professional.
    If anyone is thinking about using his services, DO IT!
    I am so excited and happy with the results! And they're not even hooked up yet!
    Well done David! @westmassguy rocks!
  • verb
    verb Posts: 10,176
    audioluvr wrote: »
    Lucky dog! I'm still waiting...
    Yep - Very lucky! I feel like Karma has befallen upon me! :smile:
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    verb wrote: »
    My new IC Cable!
    The speakons are for the IC only. :smile:
    Oh ok, nice! Sorry, not very well versed on SDA related things.
    verb wrote: »
  • verb
    verb Posts: 10,176
    Clipdat wrote: »
    verb wrote: »
    No worries my friend! I didn't even know SpeakOn's existed before joining CP!
  • westmassguy
    westmassguy Posts: 6,850
    audioluvr wrote: »
    Not for long
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • westmassguy
    verb wrote: »
    Glad you're a happy camper. Was my pleasure
    Viking64 Posts: 7,587
    Nice to BOTH Daves.
    pitdogg2 Posts: 27,164
    Clipdat wrote: »
    verb wrote: »
    My new IC Cable!
    Rookie
  • Jaybeez
    Jaybeez Posts: 748
    I've read this entire thread three times, as am getting ready to go after my recently acquired 1Cs.
    How did you re-attach the caps and sides?
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
  • verb
    verb Posts: 10,176
    My plan is to use Loctite construction adhesive to attach the new side panels. For the end caps, I plan to use mechanical fasteners. Double ended studs, one with a wood screw end, the other end a regular thread. The wood screw end goes into the end cap, then drill through holes in the cabinet, and secure with nuts. I believe the higher end SDA cabinets attach the end caps in this way.
  • verb
    verb Posts: 10,176
    Available at local hardware stores.
  • Jaybeez
    Jaybeez Posts: 748
    Ah makes sense. Thanks for the tip!
    WiiM Mini
  • verb
    verb Posts: 10,176
    Always. You’re welcome!
  • verb
    verb Posts: 10,176
    So today after doing yard work, general cleanup outside, cleaning up the garage, and hooking up my new sub from @f1nut and @monepolk , I had some time this evening to work on my 1C's a bit.
    I finished sealing up the cabinets finally! :smile:
    It's not easy to get your arms inside the cabinet to apply the seal. A regular caulking gun is too big. And the loctite squeeze tubes are a bit unwieldy, as you have to hand squeeze the stuff out, while already being in a contorted state with your arms inside the cabinet!
    I used the below for a majority of the sealing, after iterating on the above forms of locticte:
    The beauty of this form is that it is pressurized, simply pull the trigger. That way, while still being contorted, you can apply the sealer pretty easily.
    Afterwards you can smooth it out with your fingers. It's messy, I used plenty of pre-moistened wipes to clean my fingers after smoothing out a bead of this stuff.
    Below is a shot of inside one of the cabinets.
    Next step is continue with the cabinet re-finishing!
  • Manticore
    Manticore Posts: 408
    They are coming along. Looking good! Look how nice and straight your center brace is. lucky bas+ard. :*
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
    audioluvr Posts: 5,973
    Missed a spot. Do around the braces. Not sure if it matters but I, being borderline obsessive compulsive...., Saw that as a potential vibration point. I also added dynomat at the center of the 4 drivers because on mine I heard some resonance when tapping around with my finger. Again may be unnecessary but my 1C's sound fabulous!
    Keep us posted!
