Front high speaker
I need help pls
I won't to bay for front highlights
And I am not sure
Or owm5 or owm3
And I am not sure
Or owm5 or owm3
Best Answers
Either one will work fine. If you can fit and afford the 5, go for that. If not, the 3 will work just fine. Not a lot of info coming through those speakers, so I would probably just go with the 3 if it were me...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I own a set OWM3's and they get plenty loud and clear. Very impressive little speakers.
For your size room, those OWM3's should be fine and also a PERFECT match to your rear elevated set. Go for it!
Answers
Let's start with what model speaker you have.
I have monitor 60
Csi3
Rtaa1 sorrond
Owm3 sorrond back
Denon avrx4400h -
And 2 psw110
Ok, I'll assume you're looking for compatible Atmos hight speakers to add to your system?
Yes friend
I see. I'll have to defer to more experienced members here, but at least we got to the crux of the situation.
What country do you hail from? Knowing that may help with the selection and apparent language barrier as well. -
If your happy with the owm3's as rears, I would get the own 5's. Run the 5's as rears and use the 3's as front height.
Room size plays a pretty important part in height speakers. Too small and they won't work. If you can mount speakers in your ceiling, I would go that route. -
Thanks for the help
I'm from Israel
And the owm3 In the ceiling under my head
They can not be dismantled(A lot of work) -
I do not want to change anything.(a lot of work) Just add then what fits best for my set
Owm3/5?
Big thanks -
Bump
I can afford to bring the 5
The truth I bought 4 owm3 and I just hooked 2 over my head.I am considering whether to replace the second pair to owm5(for front high)
In any case, I still have not received an exact answer!
Thanks anyway -
Thanks anyway
A forum member asked you " How big is your room?"
You haven't answered.
You didn't come out and say IN THE BEGINING you bought 4 of those OWM3"s. You want answers but you leave out IMPORTANT parts that would be of GREAT help to us who want to help you. Do we have to pry info out of you after every post?
If you have the 3's use them.
Your front 3 are the most important, followed by the side surrounds. These 5 speakers, as well as a good sub, are the basis of any surround system. Getting the 5.1 part of your system right is the most important part of a good surround set-up.
If your going for ATMOS, which it seems that you are, most people feel a 5.1.2 system is the next step. If you placed your owm3's on the ceiling, you have the 5.1.2 set-up.
The owm 3's will work fine for front heights, but if you plan on mounting these on the ceiling, and fairly close to the display, i would think your speakers are closer to a 5.1.4 set-up than it would be a 9.1 set-up.
For that matter, I would probably configure the speakers in the AVR settings as a 5.1.4 even if you mounted the owm 3's high on the front wall.
Little long and drawn out answer, but with ATMOS, you have a lot more options in speaker configuration and assaignment. -
Sorry I did not see it!
My room it's 5m/3m
And yes I bay 4 pcs owm3.
But I open one set!
Now I have 7.2
And yes the owm3 Over my head
I want 9.2
My equation is if to open the new set And place them up in front of me.or Replace them to m5
Thanks everyone for the help I greatly appreciate it❤ -
Big thanks Tony❤
Tomorrow I'll hang them -
If you hang speakers anywhere near your projection screen, make sure they are shielded so your projected image doesn't distort.
Yes, of course.
And they'll be up front at the edge
Thanks for the valuable group help
