Front high speaker
I need help pls
I won't to bay for front highlights
And I am not sure
Or owm5 or owm3
Best Answers
  • rooftop59
    rooftop59 Posts: 8,120
    Answer ✓
    Either one will work fine. If you can fit and afford the 5, go for that. If not, the 3 will work just fine. Not a lot of info coming through those speakers, so I would probably just go with the 3 if it were me...
    Game Room 5.1.4:
    Bedroom 2.1
    Tony M Posts: 12,034
    Answer ✓
    I own a set OWM3's and they get plenty loud and clear. Very impressive little speakers.
    For your size room, those OWM3's should be fine and also a PERFECT match to your rear elevated set. Go for it! :)
Answers
  • FestYboy
    FestYboy Posts: 3,861
    Let's start with what model speaker you have.
  • tomtrip
    I have monitor 60
    Csi3
    Rtaa1 sorrond
    Owm3 sorrond back
    Denon avrx4400h
  • tomtrip
    And 2 psw110
  • FestYboy
    Ok, I'll assume you're looking for compatible Atmos hight speakers to add to your system?
  • tomtrip
    Yes friend
  • FestYboy
    I see. I'll have to defer to more experienced members here, but at least we got to the crux of the situation.
    What country do you hail from? Knowing that may help with the selection and apparent language barrier as well.
  • rpf65
    rpf65 Posts: 2,127
    If your happy with the owm3's as rears, I would get the own 5's. Run the 5's as rears and use the 3's as front height.
    Room size plays a pretty important part in height speakers. Too small and they won't work. If you can mount speakers in your ceiling, I would go that route.
  • tomtrip
    tomtrip Posts: 13
    Thanks for the help
    I'm from Israel
    And the owm3 In the ceiling under my head
    They can not be dismantled(A lot of work)
  • tomtrip
    tomtrip Posts: 13
    I do not want to change anything.(a lot of work) Just add then what fits best for my set
    Owm3/5?
    Big thanks
  • tomtrip
    tomtrip Posts: 13
    Bump
  • tomtrip
    tomtrip Posts: 13
    I can afford to bring the 5
    The truth I bought 4 owm3 and I just hooked 2 over my head.I am considering whether to replace the second pair to owm5(for front high)
  • tomtrip
    tomtrip Posts: 13
    In any case, I still have not received an exact answer!
    Thanks anyway
    tomtrip wrote: »
    Thanks anyway
    A forum member asked you " How big is your room?"
    You haven't answered.
    You didn't come out and say IN THE BEGINING you bought 4 of those OWM3"s. You want answers but you leave out IMPORTANT parts that would be of GREAT help to us who want to help you. Do we have to pry info out of you after every post?
  • rpf65
    rpf65 Posts: 2,127
    If you have the 3's use them.
    Your front 3 are the most important, followed by the side surrounds. These 5 speakers, as well as a good sub, are the basis of any surround system. Getting the 5.1 part of your system right is the most important part of a good surround set-up.
    If your going for ATMOS, which it seems that you are, most people feel a 5.1.2 system is the next step. If you placed your owm3's on the ceiling, you have the 5.1.2 set-up.
    The owm 3's will work fine for front heights, but if you plan on mounting these on the ceiling, and fairly close to the display, i would think your speakers are closer to a 5.1.4 set-up than it would be a 9.1 set-up.
    For that matter, I would probably configure the speakers in the AVR settings as a 5.1.4 even if you mounted the owm 3's high on the front wall.
    Little long and drawn out answer, but with ATMOS, you have a lot more options in speaker configuration and assaignment.
  • tomtrip
    tomtrip Posts: 13
    Sorry I did not see it!
    My room it's 5m/3m
    And yes I bay 4 pcs owm3.
    But I open one set!
  • tomtrip
    tomtrip Posts: 13
    Now I have 7.2
    And yes the owm3 Over my head
    I want 9.2
    My equation is if to open the new set And place them up in front of me.or Replace them to m5
    Thanks everyone for the help I greatly appreciate it❤
  • tomtrip
    tomtrip Posts: 13
    Big thanks Tony❤
    Tomorrow I'll hang them
    Viking64 Posts: 7,835
    If you hang speakers anywhere near your projection screen, make sure they are shielded so your projected image doesn't distort.
  • tomtrip
    tomtrip Posts: 13
    Yes, of course.
    And they'll be up front at the edge
    Thanks for the valuable group help
