Front high speaker
I need help pls
I won't to bay for front highlights
And I am not sure
Or owm5 or owm3
Best Answers
  • rooftop59
    rooftop59 Posts: 8,120
    Answer ✓
    Either one will work fine. If you can fit and afford the 5, go for that. If not, the 3 will work just fine. Not a lot of info coming through those speakers, so I would probably just go with the 3 if it were me...
    Game Room 5.1.4:
    Bedroom 2.1
    Tony M Posts: 11,734
    Answer ✓
    I own a set OWM3's and they get plenty loud and clear. Very impressive little speakers.
    For your size room, those OWM3's should be fine and also a PERFECT match to your rear elevated set. Go for it! :)
Answers
