PSW505 not powering up
koohead
Recently discovered my sub was not producing any sound so looked at the back and sure enough no power indicator. Tried a different outlet but still nothing. I looked at the fuse and the wire seems intact...at least the part that is visable through the glass. I popped it back in and turned the sub on and briefly got a red then green, which slowly faded to nothing.
Anyone have any thoughts? TIA
From that description it appears you have an intermittent connection at the IEC connection on the back side of the amp plate.
Thank you for the thoughts. Anyone have a diagram to show which specific connection I should examine? Or am I better off taking this to a professional? I've built computers, but amplifiers and powered subs are definitely not my forte.
If I get a chance this week, I'll pull the plate amp on one of mine, point out the guts to pay attention to.
Quick Update...called into Polk Tech Support and spoke to Gary. Provided the description I gave above and he indicated it is likely a bad power supply. As the sub is only about 19 months old he quickly processed an order for a replacement board and referred me to some youtube videos on how to disconnect the wiring harness inside. Great customer service experience...thank you FestYboy for your reply and offers to help. I'll provide an update once I receive the new board and let you all know if it resolves the issue.
Another Update: Sadly the part I need is out of stock...and ETA is end of March. So looks as if it'll be another 3-4 weeks without a sub. Support (Gary) did offer to try to help me out somehow if I would shop my non-working sub to them, but shipping a 50lb package is pretty cost prohibitive so I'll wait it out.
Hello,
Usually just the bass amplifier is sent, not the complete subwoofer. It's fairly easy to remove. -
Agree Kenneth...was just mentioning that Support was trying to go the extra mile for me if I were willing to ship the complete sub back.
Ah, I see. Send an email to Ken.Carter@soundunited and explain the circumstances and mention that you've joined Club Polk and he'll work with you.
Thanks appreciate that...will reach out to him Wednesday
