Question re IEC connectors: 15amp vs 20amp
Joey_V
Joey_V Posts: 8,603
edited February 2018 in 2 Channel Audio
So, I have a Torus/Bryston RM15 coming in. The output connector (on the back of the unit) is 20amp. I don’t have a special power cord that has a 20amp iec connector.
All my 4 wel power cords are 15amp.
Now, the options are:
1. Use the stock power cord.
2. Send my AQ Wel power cord to AQ for 20amp iec retermination for $500.
3. Trade my newer version 15amp Wel for his older version 20amp Wel. Same length, he gives me $400.
4. Buy a Pangea 20 to 15 adaptor for $29.
I guess my most pressing question is - will putting a 20 to 15 amp adaptor have a significant sonic impact??
Rather than go through the trouble of having my wel reterminated or downgrading to the older version.
Though $400 sounds good too.
https://www.amazon.com/gp/aw/d/B06XY6TW67/ref=mp_s_a_1_7?ie=UTF8&qid=1519504350&sr=8-7&pi=AC_SX236_SY340_QL65&keywords=20+amp+to+15+amp+adapter+iec&dpPl=1&dpID=410ZgKGl44L&ref=plSrch#immersive-view_1519504463344
    F1nut Posts: 51,886
    Option 4 and sleep well.
  • Joey_V
    Joey_V Posts: 8,603
    Well that was quick. Good to know
    F1nut Posts: 51,886
    Shunyata makes one as well....costs more of course.
  • Joey_V
    Joey_V Posts: 8,603
    Yes funny you mention that, my friend just texted me the link and picture. $150 for it... if I squint that's pretty much the cost of retermination. I would check again to see if retermination is really $500... that seems like an awful lot if they are just changing out the female end of the cord...
    Pangea for $29, makes sense... I doubt I could tell the difference between an inch of copper.
  • Joey_V
    Joey_V Posts: 8,603
    pitdogg2 Posts: 27,169
    I'll echo Jesse, but I guess I'm wondering why they put a 20amp IEC on it to begin with? Does it really pull that kind of amperage?
    F1nut Posts: 51,886
    If it is rated to pass 20 amps and has 20 amp outlets installed it has to have a 20 amp inlet.
    Technically speaking, the owner could swap the 20 amp inlet for a 15 amp, but if they sold it like that down the road and bad juju happened they may open themselves up for legal action.
  • Joey_V
    Joey_V Posts: 8,603
    I believe if it’s a power conditioner then more current capacity is welcome, probably why even though the outlet plugs are 15a, the inlet is 20a
    Got it I'm sorry i thought it was i piece of audio gear not a power source.
  • Joey_V
    Joey_V Posts: 8,603
    I believe even if aq reterminated my wel, it would just be the iec section but the wire is the same. I think stock wel should handle the amperage into a 20a iec
    F1nut Posts: 51,886
    Joey_V wrote: »
    If it has a 20 amp inlet it has to have 20 amp outlets installed.
    F1nut Posts: 51,886
    Joey_V wrote: »
    Yep, same cord, different IEC termination.
  • GlennDog
    GlennDog Posts: 3,152
    Please . . .
    Bigger, Better, More! You know you WANT it!
    http://www.psaudio.com/directstream-p20-power-plant/
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • Joey_V
    Joey_V Posts: 8,603
    GlennDog wrote: »
    Please . . .
    Hahaha omg... I have read about this from AA.
    Yes, would be nice.. but I'm not wanting to spend $10K for a power unit. Plus my wife banned me from non-lateral movements until 2019. :(
    The Torus RM15 gets lots of good press... plus at the price I got it for, it's a steal.
